Question about Canon imageCLASS C2100 Laser Printer
It stated paper jam.. I opened the cover and removed the paper that was stuck... then it printed to part pages just random ink.. then stop and displayed the message Service Call E000
  • 319 Answers
Www.fastrepairguide.com/printer.../hp-laserjet-printer-error-code.html
Posted on Aug 03, 2010
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
Please help with my problem. I recently printed a report and the paper got stuck. I managed to remove the paper jam but have since had problems with the pages coming out blank. I left it over the weekend...
A peace of paper is proberly still caught inside the machine.
proberly under the carriage unit that houses the cartridges.
Open the printer and see if you can find any peaces of paper that could
be causing the fault
Feb 14, 2011 | Office Equipment & Supplies
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
Regular paper jams and printed images are not straight
hi,
follow these steps:-
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks!
mannu_rakesh
Aug 04, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Paper jam
Some of the Ink Jets have a cover in the back of the printer that you have to turn a lock to remove and you could have some paper stuck back there.
Mar 03, 2009 | HP DeskJet 3940 InkJet Photo Printer
Paper jam after first page prints.
Most likely something in the printer or software is set to an improper paper size. It's saying jam because it prints the first page and registers an incorret size.
Check BOTH the printer itself and the program you're printing from.
Feb 26, 2009 | Dell 1600n All-In-One Laser Printer
Paper jam notification after printing one page, no paper jam
try this
alternative :
Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Paper curl
When a paper jam occurs, the printer will stop printing and the Continue (1) and Paper Jam (2) lights on the operator panel will come on. See the illustration below.
pattlnk_1052005_1635-enus20238_oppaneljamlights_e230_en_us.gif When you experience a paper jam, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following:
  1. If you are feeding paper from a paper tray, first remove the tray. Look for and remove any jammed or damaged paper you find.
  2. Open the front cover and remove the print cartridge assembly.
    IMPORTANT!
    Do not leave the print cartridge assembly exposed to direct light, especially sunlight, for an extended period of time. Extended exposure to light will damage the green photoconductor roller and cause print quality problems.
  3. Remove any paper you find jammed in the area behind the print cartridge assembly.
  4. Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap.
  5. Open the rear exit door/cover of the printer and remove any jammed paper you find there.
  6. Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed.
  7. Press the Continue button to resume printing. NOTE: The printer should reprint the page(s) that caused the paper jam.
  8. If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For more information, see the 'Secondary Error Codes' section on page 69 of the User's Guide.
Sep 04, 2008 | Lexmark E232 Laser Printer
Canon imageCLASS C2100 Laser Printer Logo
71 people viewed this question
old marine
old marine
