Question about Refrigerators
Frigidare side by side. Ice maker is fine but the water in the door comes out everywhere but the outlet when you push the lever. I am thinking the tube came off after the valve. How do I get at the valve inside the door? I dont see any easy access to it.I
    Genius:
  • 1,073 Answers
No valve in the door just a tube, you can pull down on the tube a little and it should help with the splatter
Posted on Apr 25, 2008
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
KitchenAid ice dispenser tray is dry - not working
Put some water in the ice mold is what I would try. wait and see if the ice maker harvest a batch. If it does drop a batch but no more then the water valve is probably shot. The ice maker itself controls the water. It does this by filling the ice mold for 7.5 seconds. Here is your Ice maker repair manual and some repair photos along with a pictorial which snows how to check the water valve.
Ice maker quit making ice
Apr 05, 2010 | KitchenAid KSRS25IL Side by Side...
The water dispenser is working fine, but there is not water going to the ice maker. The ice maker is turned on. I have removed the filter and put in the bypass plug. Any suggestions?
Switch the conectors going to the inlet valve.  Then open the freezer door, hold the switch to make the freezer think its closed and push the water button.  If water comes out by the ice maker then the valve is good and your ice maker needs to be replaced. If no water comes out the inlet valve needs to be replaced
Oct 25, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
No water going to the ice maker
Is the sensor that senses a full ice bin clean....it is a little light or it is a lever. If is thinks your bin is full it probably won't run water. There is a separate valve for the ice maker. It may be bad or have a bad connection on it.
Jan 27, 2008 | Kenmore 25.1 cu. ft. Side-By-Side...
Frigidare FRS23KF6CB manufactured 03/07 ice maker water fill wont shut off
There is a float in the icemaker which controls water height. I'm going to bet the float is jammed or the switch it controls is bad.
Dec 08, 2007 | Frigidaire FRS23KF7AB Side by Side...
No water from dispenser
If the ice maker is still working then water of course isn't an issue. The water dispensor has a solenoid valve that opens to let water flow... do you hear a "click" from the back of the frige when the water lever is pushed? If not, the valve is likely bad. Another possibility is the switch behind the water lever itself is not being pressed hard enough or even broken, see if you can press the switch with your finger up inside behind the lever area (flashlight needed to see up there). If that lever isn't hitting the switch it won't work of course but it could be a bad switch too. Sometimes the little plastic pins that hold the switch in place get broken by slamming a glass into the lever over time. In other words the switch is fine but just hanging inside the door area never to be hit by the lever again. I would be good to check it by pulling the cover off that are and visually inspecting the whole back side of the lever area/switch are for broken parts. The link below may help you with parts and diagrams to see the unit better. http://www.partselect.com/KenmoreModels.aspx?ModelNum=106.54382300&searchTerm=
Nov 23, 2006 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
