Question about Whirlpool ACQ108XL Air Conditioner
Ac humming and not cooling what do I do - Whirlpool ACQ108XL Air Conditioner
Not cooling room and every 45 seconds it makes a hum noise
window unit ac !! not a fridge . the hum you hear is the ac compressor trying to come on , but due to loss of gas charge it shuts right off again , this will require a professional ac repairman to fix this , 1st he needs to find leak then repair leak then add back lost gas charge , watch cost of all these services vs cost of entire new unit , it could get expensive
Jun 24, 2015 | Refrigerators
My carrier ac roof top ducted unit started spitting out small amounts of water now and then, I changed filter. Now with ac in off position I am hearing a humming noise coming from the unit, what can this...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
Mar 02, 2018 | Dometic Rooftop RV Air Conditioner
I have a frigidaire wall mounted ac unit. It isnt cooling like it should be and when the motor tries to come on my lights dim and there is a humming noise for just a few seconds before the hum stops. The...
Possible you just need a good maintenance. Clean coils flush and vacuum drain check pressures amps and capacitors change batteries and filter.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 01, 2017 | Frigidaire FAS155K1 Air Conditioner
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
When I turn on the AC I only get a hum, no fans or compressor
Check the capacitor to see if good. need help get to me ken
May 08, 2010 | Frigidaire FAS156N1A Air Conditioner
DX-2517 AC HUM
As you posted/described, internal work had been done at the factory then perhaps the source/cause of the AC hum is external.
If the unit is being used as a base with a regulated power supply, then the power supply has to be checked. This would include the big capacitor, the diodes and the regulator transistors. On certain occasions, loose transformer E core can also cause the hum.
There are also instances that other electrical devices can cause the hum, these can include fluorescent lamps, air purifiers, dehumidifiers and others.
In some cases, it can be loose grounding of the antenna mount or the braided/shield wire solder to the PL-250 connectors.
If it were mobile, then the antenna grounding is also a possibility. If the hum is higher than 60Hz and goes with the engine RPM, then the alternator of the vehicle has to be checked.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Galaxy Radios DX-2517 CB Radio
Hums and freezes up????
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing. common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize. Have the fan motor checked. The fact that the fins are freezing, means that there is enough freon and the compressor is working.
May 29, 2007 | Frigidaire FAS155K1 Air Conditioner
Whirlpool ACQ108XL Air Conditioner Logo
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
