Question about NEC MultiSync 1760NX 17" LCD Monitor
My power supply is burnt and ic with resistor value not readable.
  • 319 Answers
Tangentsoft.net/audio/cmoy-tutorial/tweaks.html
Posted on Aug 03, 2010
Can i have TCL 2127 model power unit IC's pin 8 resistor value
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. Schematic diagrams to some popular model TVs are given.
Jan 05, 2014 | Televison & Video
2 resistors are burnt rz126 and rz125 but i dont know the value of these resistors samsung SPA43W6HPX
Both of those resistors are 3.9 ohm 2watt metal film resistors for the convergence ICs. The ICs will most likely need replacement as well.
Mar 03, 2011 | Samsung HCL4715W 47" Rear Projection...
RK46 BURNT CANNOT SEE COLORS ONLY 2 STRIPS DARK AND 2 STRIPS LIGHT. WHAT IS THE OHM VALUE AND DO I INSTAL GOLD STRIPS TOWARDS IC OR AWAY. HATACHI 43FWX20B DP24 JOE
rk46 is 1.8 ohm resistor---rk54 is the same value, rk 62 is 2.2, and Rk 42 is 3.3 ohm. It does not matter which direction it is installed---it is a resistor
If you have any questions feel free to let me know.
SD TECH
Oct 08, 2009 | Televison & Video
The blue convergence seems to be off on the tv, and i'm not sure how to fix it
Take the back of the tv off but first unplug it Then look to the lower right and you should see 2 convergence IC's (STK392-110) and also look for a burnt resistor around them. If no burnt resistors replace convergence IC's with STK392-180 If you have a burnt resistor then respond back to me with location number on the board and I will get back to you with the value.
Jun 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Burnt resistors
Depending on where you bought the ICs you could have fried the new ICs when powering it up with burnt resistors as the green is controled by both ICs one IC controling the horizontal green Convergence and the other IC controling the vertical green convergence. Have you checked all the convergence resistors out of circuit?
May 18, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic COLOR CT-27G14A
check Vertical IC out (LA78..) and resistor voltage supply from flyback transformer to this ic. Check the STR main power supply(and resistor near, change value), some times seems good out main board,but in operation not good
May 18, 2008 | Televison & Video
Burnt resistor
You have to check what could cause these resistors to be burnt. It might be because of caps or IC. Unfortunately, I don't have this type of circuit board. If you cannot find it, try with the same value of resistors that are placed close to these fault resisters.
Mar 16, 2008 | Computers & Internet
PT-51HX40b BP819
Only use the same part number when replacing convergence amps, or you will need to replace all of the power resistors with recommended values for the convergence amps subsituted.
Dec 08, 2007 | Panasonic PT-51HX40 51" Rear Projection...
NEC MultiSync 1760NX 17" LCD Monitor Logo
154 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
