Question about Velbon Sherpa DV7000 Tripod
Im missing the plate/adaptor w/1/4 20 threads
  • 685 Answers
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen.
Posted on Sep 23, 2010
I have a Better Chef model # IM-335 and the heating element just went bad. Is there a place I can get a new one?
apparently not. They are $31 new.
1500W Burners Hot Plates eBay
better chef model im 335 spare parts Google Search
Better Chef IM-302DB Stainless Steel Dual Electric Burner - Free ...
https://www.overstock.ca > ... > Kitchen Appliances > Cooktops, Burners, & Hot Plates
Rating: 4.5 - ‎17 reviews - ‎US$38.75 - ‎In stock
Shop for Better Chef IM-302DB Stainless Steel Dual Electric Burner. ... Stainless steel brush finish; Dual self-cleaning coiled heating plate; Safety on/off switch; Adjustable temperature thermostat control; Indicator ... Model Number, IM-302DB.Missing: 335
Better Chef Dual-element Electric Countertop Range - Free Shipping ...
https://www.overstock.ca > ... > Kitchen Appliances > Cooktops, Burners, & Hot Plates Rating: 4.4 - ‎30 reviews - ‎US$30.99 - ‎In stock
Shop for Better Chef Dual-element Electric Countertop Range. Free Shipping on ... This countertop range features 1,500-watts of total power and adjustable heating controls. 1500-watts total ... Model Number, IM-306DB. Country of Origin ...Missing: 335
Jun 04, 2018 | Dryers
The tension knob will not turn below four. The thread keeps breaking.
check that the thread is between the plates and not behind them
thread breaking can be from wrong size needle eye, poor quality thread , old thread and needle/ eye timing
Dec 11, 2015 | Singer Merritt 8734
Why is the thread a line on bottom of fabric?
Clean the bobbin case and all the parts under the plate. You may have a bent needle, so replace the needle. The bobbin case has a tiny point on it that catches the thread, that may be broken and missing the thread as it spins.
Feb 17, 2015 | Brother LX3125 Sewing Machine
I have a 98 F800/5.9 cummins. Pumper truck w/bationi pump. Pto leaking. How do I know what to order.please. help
you are not specific about where the pto is leaking. If it hoses to the pump then replace the hoses and fittings.If it leaking between the pump and the gear box then you will need 2 gaskets. There is a gasket that goes between the adaptor plate and the box opening and another between the pump and the adaptor plate. Use good quality gasket goo( silastic blue ). Ensure that and mounting bolts that go through into the oil section of the box are sealed around the threads or have good copper washers under the heads. If the installation was done correctly initially then it is possible that le leakage is from loose bolts
Dec 17, 2014 | Cars & Trucks
How to solve the problem when my secondhand nissan frontier engine doesn't fit to the old gear box
probably the best way to solve the problem is to fit new engine and gear box as a unit and give the old box a miss. If you cannot do that check around for a speed shop that sells adaptor plates or if you have a good engineering shop handy have an adaptor plate made
Oct 01, 2013 | 2002 Nissan Frontier Crew Cab
Singer 6038 tension dial not working
there should be small washers ( discs with a tapered flange to direct the thread between the plates ) if they are not under the spring behind the tension adjuster knob then that will be your problem
if they are there then check that the tread is between the plates and not behind them
missing plates are available from a sewing machine mechanic sgop
May 07, 2017 | Singer 6038 Mechanical Sewing Machine
Top thread is ok but bobbin thread misses stitches at will, zigzag stitches don't sew but a straight line. changed needle, sanded burrs off pressure plate, cleared bobbin chase of lint. what have I...
check tension usually 3 or 4 is good
clean under needle plate where feed dogs are for lint
is the flat side of the needle toward the back of the machine
rethread machine
is needle the right one for the fabric & thread
it might also need to be serviced
Nov 24, 2010 | Kenmore Sewing Machines
How do you secure a rear number plate
There is usually a small threaded metal clip behind the numberplate. This gives the screw something to thread into as the bodywork of the car isnt enough. If this is missing you could try drilling a new hole (smalled than the screw) in the area behind the plate to fix it to or a less permanent solution would be double sided tape.
Dec 21, 2009 | 2001 Honda Odyssey
Raising the bobbin thread
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Aug 26, 2009 | Singer 132QRFB Mechanical Sewing Machine
Do all filters need an adaptor?
you can get screw-in filters, but those that require adaptors or holders are more versatile, as you can use them on a variety of different sized lenses.
Sep 07, 2005 | Fuji FinePix S5500 Digital Camera
Velbon Sherpa DV7000 Tripod Logo
59 people viewed this question
Top Velbon Photography Experts
JP Services
JP Services
Bill Eager
Marvin
Marvin
Are you a Velbon Photography Expert? Answer questions, earn points and help others
