Question about Kitchen Ranges
Single wall oven shows F7 E6 on display window, reappeared after shutting off power
    Genius:
  • 1,073 Answers
Replace the electronic control
Posted on Apr 25, 2008
F6 E6 error code?
This fault is a communication error at the appliance manager, could be a loose wire or a bad display transformer, either way you will need a certified technician to fix this issue, there is no simple plug and go issue to resolve. I personally found the problem to be the transformer not send voltage to the appliance manager. This is solvable but needs someone who understand electronics to correct this issue.
F6 E0 Oven user interface - lost communication E6 Oven appliance manager 1 (upper, single) - lost communication
This is directly from the tech sheet of your oven and directly from the factory web site.
Good Luck
Dec 03, 2013 | KitchenAid KEBS179B 27" Built-in Electric...
The display shows F 7 E 6, the oven buttons do not work but the broiler acts like its coming on but does not message. The maual asked to cut the power for 30 secs and restart. Tried that did not work...
http://appliancejunk.com/ge/cookingproduct/31-20105.pdf
Please find above your service and repair manual, use this to troubleshoot and resolve your issue
This website below will also assist in locating an reolving your problem.
http://www.acmehowto.com/howto/appliance/range/erange.php
E6 - Drain pump error Water level does not decrease to reset point within 15 minutes from draining water from the washer. Press POWER button. No other buttons work:
· Check wiring harness
· Check pump motor
· Check circuit board
0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
Aug 20, 2010 | GE Ovens
I got an F7 error code and now the display is blanked out. JTP20 series wall oven
F7 Stuck Button
1. Function pad button stuck or
2. Bad clock. Try to free stuck button or
3. Replace Electronic Range Control (ERC).
Nov 25, 2009 | GE JTP20 Electric Single Oven
GE range displaying codes F7 E6, unable to turn oven on.
F7 E6 shows that Function pad button stuck or Bad clock try to Unstick Button or Replace Clock also if persist then check the connections to the contol panel
Oct 18, 2009 | GE Kitchen Ranges
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
I have an GE oven and the display is showing F7 and flashing E6
F7 normally means there is aproblem with the key panel. Many times it needs to be replaced.
Sep 22, 2008 | GE Kitchen Ranges
GE wall oven display say F7, Bake and alarm sounds
F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
Aug 06, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
Ge wall oven display says F7
Your problem is most likely caused by a short between sections of the ribbon cable between the touchpanel and the electronic control. The solution is to insert a slip of paper between the sections where it exits the touch panel. See the attached photo. If you have a metal touchpanel, insert slips of paper on either side of the ribbon cable as well. CAUTION: Be certain to turn off the power to the oven before you poke your fingers in and around the touchpanel. My solution has worked for hundreds of folks. Don't worry about the paper burning. If you have questions, contact me at hutchipop@yahoo.com.
May 29, 2007 | GE JKP30WMWW 27" Built-in Single Electric...
Kitchen Ranges Logo
104 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
