Question about Zanussi Washing Machines
My zanussi washer dryer keeps flashing E40 whenever I try and do anything
    Sniper:
  • 174 Answers
Can be faulty door lock or wiring to the lock. also door ****** can be displace in the door . the handle shaft can slip out this stops door closing and actuating the switch correctly.e40 relates to starting the machine with door open.
Posted on Aug 03, 2010
My electrolux washer dryer ewx14540w keeps flashing e40 and won't do anything, please help
Hi dear.Related to your problem,E40 means:
• The door is not firmly closed. (E40)
• The machine is not plugged in or there is no power
at the socket.
• The main fuse has blown.
• The type of fabric has not been selected by means of
the relevant selector dial.
• The Start/Pause button has not been depressed.
• The Delay Start option has been selected
Please checked those followings.I hope that helps.Thanks.
Feb 13, 2011 | Electrolux EW1209i Front Load Washer /...
Error e40 come up on my washing machine zwd 1472 s
E40 normally points to a fault at the door switch,sometimes when the door switch fault occurs it can also cause damage to the main P.C.B.(Programmer).As this machine is still in the major parts warranty it would be advisable to get in touch with Electrolux.
May 03, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
E40 error door light flashing and clicking noise
E40: Door open, Interlock, wiring or main PCB most likley going to be faulty door interlock.
Turn the power off, unplug the machine and take the top off your machine and on the front right of the machine there is a plastic case with lots of wires.
Put the wires out one block at a time, keep putting them in and out, this will help the connection to seat.
Try the machine again and the problem should be solved.
If not you may need a new board.
Mar 10, 2010 | Zanussi IZ161S Front Load Washer
Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Nov 14, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi zwf1631w error code e40
hiya
E40 is the fault code for the doorlock, these are relatively cheap and easy to fit and if an independent (non zanussi) engineer was to fit it, you will probably be looking at around £40-£50 all in as a rough guide.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Nov 10, 2008 | Zanussi ZWF1440 Front Load Washer
I have problem E40 on Zanussi zwd 1680 w
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected.
Oct 03, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi zjd1219
Hi
Machine is showing E40 ERROR
Sep 07, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Feb 28, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
279 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
