Question about Microwave Ovens
How to remove an under-the-counter microwave.
I've already unscrewed the four bolts that attach the microwave to the cabinet above, but the microwave doesn't budge. What can I do?
Thanks
  • Bradio Jun 17, 2008
    need to remove an under the counter microwave oven. removed the four bolts from above but it won't budge. it was new in 1984 and is model number RVM60 001 and is a Hotpoint Counter Saver.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and full model number and we'll see if we can get the installation (and removal) instructions for you.
SOURCE: can't remove under counter microwave.
I think there are only three very long bolts that can be used to attach this microwave to the cabinet floor or shelf. Grease, paint, varnish all can make the case stick to the cabinet. You might try running a putty knife or scraper around all the exposed edges keeping the top bolts in place so it will not fall down.
Posted on Aug 23, 2007
SOURCE: Microwave installation
Hi there - just figured out how to get mine out. Here is what I did. There are two screws at the top under the faceplate. There is brace on each side with 2 screws on the bottom and one facing out. Remove the two that face out. Next look under the unit and there is a brass looking cover with 2 more screws. Mine had writing on it about servicing professionally. Remove that two screws, the two power connections and the unit should slip right out.
Posted on Oct 08, 2007
  • 619 Answers
SOURCE: Microwave installation under cabinet, no rear wall
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Posted on Jan 18, 2008
SOURCE: removing under cabinet GE microwave
Remove the face plate above the door. You will see two bolts where you can use a screwdriver to turn them (unlock them). Those bolts go all the way to the back of the microwave. Once you have turned them (you do not need to remove them), you will need to remove the one - three screws that come in from the cabinet above. You may have to jar it loose if it still stuck.
Posted on Aug 31, 2008
  • 140 Answers
SOURCE: how do i change a fuse in a kitchenaid overhead microwave
Hello,On the front of the microwave above the door is a louvered panel. You need to remove the panel ( usually it just pulls straight off ) and inside on the left you will see a metal rod that's bent 90 degrees. That is the lock handle. While lifting on the front of the microwave pull that handle out to release the lock. The front of the microwave will tilt down, you may have to help it start tipping. Once the microwave is tipped down you have to lift the back that is against the wall to unhook it from the wall mounting panel. Be careful to feed the power cord through the cabinet hole as your lowering it. Good luck and let me know how this works.
Posted on Jan 02, 2009
How to uninstall a Whirlpool microwave Hood Combination? Model MH6600XV
Unplug the range and move it out of the way.
Open the cabinet above the microwave.
Unplug the power cord.
Remove the 2 bolts going through the cabinet into the top of the microwave.
Have a helper hold the microwave in place before these bolts are removed.
After the bolts are out,assist the helper by lowering the front of the MW and lift the back of it off the mounting bracket attached to the wall.
They are heavy and awkward.
A helper must be used.
Jan 21, 2011 | Microwave Ovens
Tip
How to replace the bulb of a microwave oven
Replacing a Built-in Microwave Oven
  1. Step 1 Locate the cabinet above the built-in microwavemag-glass_10x10.gif oven. Find two screwed-in bolts. Unscrew the bolts while someone holds the microwave steady.
  2. Step 2 Unplug the electrical cord from the cabinet above and snake the wire down the hole towards the microwave oven. Continue having someone hold the microwave steady.
  3. Step 3 Roll microwave to left or right to set it free from the mounting bracket in the back. The microwave oven should now be unlocked from its position and can be removed completely from the area.
  4. Step 4 Install the mounting bracket on the new microwave that was included in the package.
  5. Step 5 Snake the electrical cord of the new microwave through the hole in the above cabinet. Plug in the electrical cord.
  6. Step 6 Lift the microwave and rest it to line up with the existing mounting plate on the wall. Roll it until the microwave is locked in place.
  7. Step 7 Use a screwdriver or electric drill to screw in bolts above cabinet into the microwave mounting bracket. This will keep the microwave securely and tightly in place. Your new microwave is ready to use.
on Apr 04, 2010 | Microwave Ovens
How to remove the old Tappen microwave oven model 56-2891 under the cabinet?
open the cabinet door above the microwave there should be four screws going thru bottom of the cabinet shelf holding it on to cabinet have a helper hold the microwave as you unscrew it
Dec 12, 2010 | Tappan Microwave Ovens
I'm removing a Maytag microwave over stove model #mmv4205aab. Would appreciate guidance. The only attachments I can see are two bolts which connect the unit to the cabinet above. I cannot see what...
Typically there is a metal mounting plate screwed to the wall and when you take the screws out of the cabinet above it it will tilt forward toward you and then you have to lift it off of some metal tabs that are on the bottom of that mounting plate. Lift up and pull away from the wall and let the cord pull out of the hole in the bottom of the cabinet. Good luck. I usually do that by myself and hook one arm under it and lift it up, but probably better with two people.
Oct 09, 2017 | Maytag MMV4205 Microwave Oven
I can't find bolts or screws that hold the unit in place. I need to remove the microwave in order to install new one.
HI there,
Here's HOW;
  1. Remove the face plate above the door.
  2. There were 2 bolts in which you will need a screw driver to loosen it
  3. This bolts go all the way to the back of the microwave.
  4. You still need to remove the one - three screws that's above of the cabinet. You may have to jar it loose if it still stuck.
Hope this helps.
Let me know for further instructions.
Aug 04, 2009 | Microwave Ovens
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
We can not remove our old Sharp R-1460A
Take off the bottom panel, underneith you will see two long bolts. have someone support the microwave and unscrew the bolts. off the wall it comes
Mar 08, 2009 | Sharp R-1460 Microwave Oven
Removing under cabinet GE microwave
Aug 27, 2008 | Microwave Ovens
I'm a kitchen remodeler, and I've seen this problem with Kenmores (so it probably exists with some other brands too. The ones I have seen have the typical bolts through the top, but there's more. The flat mounting plate on the wall has an protruding piece that fits well into the body of the microwave when the unit is slid into place. It has a threaded hole in the end of the extension, and the sheet metal screw or bolt that goes into this is causing your anguish. To access this, you must remove the top front louvers (maybe some other trim plates as well). You'll eventually find the bolt that unscrews with a horizontal screwdriver. Chris Harrison, Richmond Refacing.
Sep 23, 2007 | Microwave Ovens
Can't remove under counter microwave.
Aug 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
142 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
