Question about HP Computers & Internet
I have a HP Laptop model pavilion dv8210us. The laptop shuts off itself when the hardware gets overheated. How can I get this issue solved?
  • beat211 Aug 03, 2010
    I have the laptop on a hard surface now.
    President:
  • 2,571 Answers
TRY,, cleaning the fans/heatsink grills.
Sometimes the overheating/shutdown is due to damage to the motherboard, and as it heats up, it flexes and expands and it just looses power.
I cleaned a friends laptop yesterday (re fitted the cpu/gpu heatsinks), got rid of virus/malware problems, it stayed on for 1 hour in safe mode, thought i had fixed it.
Booted normally and of it went after 5 minutes.
Google your model number to see if this is a common fault for you
Posted on Aug 03, 2010
    Guru:
  • 1,082 Answers
Do you have the laptop on a hard surface or is it on your lap or a pillow? You must have lots of air circulation to keep the laptop cool.
I would suggest buying a laptop cooler, a device that has fans and plugs into the USB ports. They are in major computer stores and usually are under $30.
How to fix the HP Laptop are shutting down by itself
Hi Walter, The link below is a YouTube video showing how to fix your lap top shutting down by it self, Also there's videos down the right side of the link that may help as well, By the way instead of using a straw I'd undo the back..........CHEERS..
Don panic Is your laptop shutting off by itself or slowing down during use
May 11, 2016 | HP Pavilion dv9000z Notebook
Headphone not working with dv8210us and xp
No need to install another drivers for Head phone..
Go to Sound icon from the task bar - properties - make it default and once plug out and insert.. then it will work...
Jan 31, 2014 | HEWLETT-PACKARD 403831-001 PAVILION...
My hp pavilion g7 is overheating and shutting down
first check your ventilation port on the side or back of your laptop. These can become covered in dust and make your laptop very hot. After you've done that, if it's still overheating, try and find a free cpu fan diagnostic tool and make sure the fan is even running or if it's running at the proper speeds. If it's not running, check your drivers. Go to the hp website, then support and downlads and lookup your model laptop. It's on the bottom of your laptop. Download the cpu fan driver if available and reinstall it. If it's still not working after all of that, your fan is shot and will need to be replaced.
Aug 05, 2013 | HP Pavilion dv7-1285dx Notebook
Pavillion dv7 1132nr runs very very hot all the time to the point it burns my hands. I have a large laptop fan cooler under it running all the time. It is also very noisy as the fan on the laptop is...
I suggest try to call the manufacturer because if happens that its causing plastic burnt or dent due to overheating that means the hardware of the machine is failing, also the automatic shutdown is caused by overheating. If your going to call the manufacturer they have special support for those kind of issue.
Feb 12, 2011 | HP Pavilion dv7-1132nr Notebook PC
My laptop shut off by itself, and wont turn back on. It is a new laptop. It is charged.
Sounds like a thermal shut down switch was tripped. In plain English that means it probably overheated. Was it on your bed or your lap. There is only one small vent that draws air in and one that exhausts it. If these a covered the laptop will get hot very fast shut down to prevent further damage. You should also use a can of compressed air to blow those vents out on a regular basis to prevent blockage.
Jun 24, 2010 | HP Pavilion g60-440US Notebook
HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook: My Hp laptop turned off by itself and wont turn on...
Make sure your Notebook is not overheat if it is then you have to make sure the fan is working and have to work on the NB by placing it on a hard surface and also BIOS update will also help to resolve the issue.
if in case the notebook is not overheating boot to BIOS screen and check if the Notebook turns off by itself in bios if it does then its a hardware issue and you need to contact manufacturer to service the notebook
May 18, 2010 | HP Pavilion dv9000z Notebook
Having problems with HP Pavilion dv9000 overheating and shutting down. I've downloaded a new bios as HP support suggested (but I think it was actually an older version of the bios that was on my laptop),...
The overheating can also be cause by the battery. Please check the following article link as it lists models affected. There's also a link in the article, if you need to contact HP's battery replacement program.
http://mobileoffice.about.com/b/2009/05/15/hp-laptop-battery-recall.htm
Oct 18, 2009 | HP Pavilion dv9000z Notebook
Laptop shutting down by itself
it looks like over heating issue. get to service to check cooling system.
thank you choosing FixYa
May 28, 2009 | HP Pavilion dv6000z Notebook
Lines on screen of HP Pavilion zd7360us
Hello, please report your story at hpverticalline.com so your computer model may be added to any future legal suits.
Jan 15, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Computers & Internet Logo
183 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
