Question about Dell OptiPlex 170L PC Desktop
I have a dell 170l computer and can not get any sound. the device manager says everything is working. i cannot adjust the volume control. the controls are grey and nothing happens when i try to adjust
    Problem Solver:
  • 4 Answers
Goto the Dell website eg. www.dell.co.uk
Click Tech support
Click Home user
Click Drivers/ downloads
Select Optiflex 170L
Confirm
Select operating system E.G .Windows XP
Seect Audio
Select Anolgue Device Drivers
Donload & setup
Lookin toolbar for download progress
The driver downloaded is "SoundMax" To check whether soundmax already exists Goto Run then search soundmax
Good luck, Gwenorm
Posted on Feb 25, 2011
Sound card working properly but no can be heard
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 16, 2011 | Dell Computers & Internet
My Dell twin speakers suddenly not working today Monday 5.9.11. Were working OK about 3 to 4 days ago. Have not disconnected anything and all plugs seem to be in order. First time this has happened in...
if your computer came with a motherboard disc the sound drivers could be on it
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 05, 2011 | Dell A215 Computer Speakers
Everything is pluged in correctly. And when i go to the control panel> Sounds, speech, and audio devices> sounds and audio devices> volume, it says that their pluged in and work, but i dont here...
also
hope this helps you
Aug 16, 2011 | Dell A215 Computer Speakers
Brand new out of the box Dell 560 set everything up and plugged in the speakers to the USB and the jack in the back and nothing no sound. the speakers are on, but the machine says no device detected. ...
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 11, 2011 | Dell Audio Players & Recorders
My speakers are not working. I made sure everything is connected properly. The speakers do not even show up under my sound device panel.
also
Aug 05, 2011 | Dell A215 Computer Speakers
No sound not working everything is plugged in
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Feb 01, 2011 | Dell AX210 2 Speakers
They are turned on but no sound. On the control panel audio options its says no audio device found. Could you please give me the correct download. thanks
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Dell A215 Computer Speakers
Wont work on new comp
hope this helps
Jan 12, 2011 | Dell PS-230 Computer Speakers
Speakers no longer work, and computer does not recognize the device. No sound.
control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 06, 2010 | Dell A215 Computer Speakers
Dell vostro 230 no sound from system speaker
hope this helps
Dec 05, 2010 | Dell Audio Players & Recorders
Dell OptiPlex 170L PC Desktop Logo
149 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
