Question about Pool & Spa
I have an A.O Smith pool pump 1hp, p/n 7-187332-20, 3450rpm, 115/230v, 56Y frame. The person I got it from dismantled it to change the bearings and took all the wires off the back of the terminal board. They did not mark anything and now I am not sure where to connect the wires. Are you able to give me the internal wiring diagram?
KMusselmann
  • 247 Answers
SOURCE: got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
Posted on Mar 18, 2009
john224
  • 1378 Answers
SOURCE: switching my hayward pool pump from 230v to 115v
Setting the pump for 115V wont by itself cause the trip. There is either a ground in the circuit or the GFI is bad. You may want an electrician to test any further than this.
Posted on Jul 04, 2009
  • 64 Answers
SOURCE: Replaced Single Speed Pool Pump Motor with 2-Speed Motor
You will need a two speed time clock to really take advantage of real energy efficiency savings. Intermatic makes one that fits in place of the original t104 time clock. You will need to run an additional wire to the pump as well. You will have the ground. Then one common wire that is always hot whether or not you are on high speed or low speed. You could make this a white wire. Then a black wire for your high speed that is energized in high speed and a red wire for the low speed. It is important that the high and low speeds not be energized at the same time, otherwise you will hear a very unpleasant sound coming from the motor, and failure and shortened life of the motor will be realized. HTH
Posted on May 29, 2010
  • 760 Answers
SOURCE: I just bought a AOSmith 1hp pool pump. I do not
Well first did you have an old one you're replacing? Check it. Second you could test your voltage with a tester (best idea then you know for sure). Third, you can look at the circuit breaker in your panel, and if it is a single breaker , it is 125V If it's a double pole breaker (two wide with wide handle) then it's 230V. Usually if it is 230V then the wires coming to it would both be black, or black and red, with a bare or green ground. Usually if it's 115V you'll have one black (hot), one white (neutral) and one bare or green(ground) but at times someone will wire one 230 with black and white. There should also be a large bonding copper jumper connected to a lug on the outside of the motor to bond your system to the pool (NOT AN EQUIPMENT GROUND)
Posted on Jul 05, 2010
john224
  • 1378 Answers
SOURCE: Wiring up Emerson 1081 pool pump. Using 230V. Is
Thank you for posting your question here on Fixya.com.
There is no polarity associated with the leads in an AC system. You simply have 2 hot wires and you can hook either one to either Line 1 or Line 2. Motor rotation is not dictated by the connection arrangement of these leads. Ground the motor with the grounding wire and again with the bond wire if one is present.
You can remove the riser that is positioned under the motor to allow for a 56 size stator to fit in place of the 48 size stator the original Hayward (AOSmith) motor was.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Nov 02, 2010
Is frame 56J interchangeable with other frames ?
When looking at a frame size you cannot change from the "J". This letter referres to the method the pump housing will bolt onto the motor. The numbers 56 refer to the physical size of the pump, specifically the distance the center of the shaft would sit off of the surface on which it rests. You can sometimes go from a 56 frame to a 48 frame but you will need to add a spacer given the smaller physical size. Some pump bases will have a stilt that can be switched around or removed to accomodate different motor barrel sizes.
Nov 08, 2014 | AO Smith Pool & Spa
How to wire the 115v/230v magnetek pool pump motor (1.5 Hp wth sq flange, 56Y) for 115V ?
if you are not a motor service person do not try this your self get the right help be safe
Sep 23, 2013 | AO Smith 1.5hp 1800RPM 56 Frame Farm Duty...
How can I run my aosmith 1hp pool motor on 115v?
LOOK ON THE MOTOR LABEL IT WILL HAVE A PICTURE ON HOW TO CHANGE IT, OR TAKE THE COVER OFF THE BACK AND LOOK CLOSE YOU WILL SEE HOW TO CHANGE IT.. jay the pool pump motor repair guy in longwood Florida 32750 .. BEST TO RUN PUMP ON HIGH VOLTAGE , IT WILL RUN COOLER AND LAST LONGER AND CHEAPER TO RUN $$$
Sep 21, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
I just installed a us pool pump motor eb841 1hp 3450rpm 208volt 56y and it is leaking water behind the square bell housing actually leaking bottom side of motor
There is a leaky water seal on the pump shaft housing between the pump and the motor.
The drain hole prevents water from going into the motor and this seal needs to be replaced before the motor is damaged.
Aug 19, 2012 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Will a smith 1hp pump fit in place of a hayward 1hp
as long as the frame size matches i.e. 56J in this case then you should have NO issue with changing the motor mfg.
US Parts Center
Aug 18, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
How do I replace the bearings in a 1hp pool motor its a st1102
Remove the motor from the pump. Unscrew the 4 through bolts located at rear of motor. Tunr the 1/4" hex screw located at the front of the motor next to the shaft 1/4 turn counter clockwise.
Tap the front housing until it is removed (may need a bearing puller to remove it. Once this is removed, use a bearing puller to remove the bearing. Next, use 12" long piece or 3/4" metal electrical conduit to tap the new bearing into place making sure that the conduit is only coming in contact with the RACE of the bearing (the inner most track).
Reassemble.
Note: A molded bearing puller is needed fot this job. A formed puller will just bend/break.
It would cost less money to pay $75 to have this done by a proffesional rather than buying a $100-$200 tool just to try to do it yourself.
Jun 03, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
Ao smith century 1 hp 56y pool pump sqeals for few minutes at start up and then is ok - sounds like bearings - unit 6 yrs - what is fix
How do I change the front and back bearings in this pool pump motor 1hp. ao smith motot I did the shaft seal last year myself but needs bearings now. thank,Bill
Feb 06, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
Pool & Spa Logo
235 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
