Question about Samsung Refrigerators
My Samsung model refrig RS267LASH/XAA (4 years old) has water accumulating in the bottom right corner on the refrigerating side. It appears to be coming from the middle drawer with cooland coils behind it. What do you think the problem is. The warranty for the compressor/coolant system is 5 years. Does it look like a warranty issue? Gyle Atter Kirkland, WA
  • gyleatterwor Aug 03, 2010
    Clarification: the water is accumulating inside the refrigerator compartment under the bottom drawer (right rear corner) below the middle drawer coolant tubes.
  • gyleatterwor Aug 04, 2010
    Thanks guys for your instructions. I'll let you know what happens. I have a repair person scheduled to come this Friday to look at the unit if I can't find the clogged drain tube before then.
  • 2,272 Answers
Its not compressor/coolant issue.The problem is related to defrost.The drain line is getting clogged and the coils getting overheated ,so this is making the frost of ice getting melted and water leaking in the refrigerator side. unplug the unit and do manual defrost procedure. keep the unit unplugged for 24 hours.Keep the doors open in unit.empty the unit and then after 24 hours connect the power to the outlet and recheck. If still the same problem then get the defrost timer and defrost board checked. Its making the clog in the drain line and that is creating the leak. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 04, 2010
    Brigadier General:
  • 3,513 Answers
Hi
The water accumulation is caused by a blockage of the freezer drain line.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Now, you have to find that drain line. Start by taking out every thing in the freezer / refrigerator. Then looking in the area above and below the floor of the freezer, try to find a place where water would naturally flow out. It could flow out the back of the space down a usually white plastic tube. You may have to take any screws out of the floor of the freezer, and side walls to expose this drain... It is always under the evaporator coils inside the freezer... It cannot be anywhere else. Once you find it, you need to clear it. What has happen probably is the green or black mold has entered the water line and reproduced to the point it is clogging the drain. This usually happens. Every time you open and close the fridge doors, you bring air, and anything in it, in and out of the tube, it can not be helped. To clear the line is not always easy. You might try to pour hot water down the drain. You might try pushing a flexible wire down the tube. Do not force as you could break something... You may have to locate any junction, bends, elbows where the line attaches to something else and loosen the line and force air into it to clear it up.
Or remove the entire drain tube and force air into it to clear a solid mold clog.
OR call the repair person, he will clear it in about an hour, knowing exactly where the line is located.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 03, 2010
    The upper drawer has an individual temp control with coils on the back. The water seems to be coming from there. Is there anything specific to that subsystem that you can add to your solution?
    Thanks,
    Gyle Atter
Water accumulating in bottom of refrig.
What is your model number? Every different model leaks differently but the same reason (defrost drain frozen shut) causes water to appear in different places in different models. Click here=> Leaking Refrigerators
I'm here should you have question, Thanks, Sea Breeze
Oct 11, 2015 | Refrigerators
Refrig. is 4 yrs old. Refigerator side just quit cooling. Freezer side seems to be working fine. Help!!! Samsung Model #RS267LBBP
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Need to find water filter on my amana model scd23vw refrig.
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
Aug 16, 2010 | Amana Refrigerators
RS267lash samsung refrig. display panel fridge
Sounds like the fan unit is faouling with ice. The solution is to remove the whole of the contents and then the units inside at the rear. Defrost same and re assemble. Its not that hard if you remove the light difuser first and the two screws. Mark the difuser for top. Then ease out the unit and remove after taking out the electrical connections. They fit only one way. The lower unit has four screws. Two under covers. Easy to unclip. The ice seal may mean that it is not that easy to remove. Defrost both the units with a hairdryer or similar and clear insulation from the fan drain. Re assemble when clear and as dry as you can. The problem will come back so be aware that you have to repeat the procedure when the fan gives signs of fouling. Paul.
Jul 11, 2010 | Samsung 26.1 Cu. Ft. Side-by-Side...
GE REFRIG. MODEL#TFX30PRYAA. side by side both
It sounds like your defrost control timer is working, but your defrost heater is most likely burnt out. It is a part number WR51X443
and is located behind the back wall inside the freezer. Turning the refrig off for 24 hours helped melt some of the accumulated frost, but not all. You will have to take that back cover off inside the freezer and melt all the frost with a hair blower, replace the defrost heater and reassemble.
Jul 01, 2009 | Refrigerators
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
Kenmore Refrig
It appears the defrost drain inside freezer is blocked or the drain tube leading to pan near compressor is clogged I would unplug refrigerator and remove the back panel in freezer to examine the drain and get back with me to let me know what you find, also get model number for your refrigerator so I can help you better. Sea Breeze Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 27, 2009 | Refrigerators
Whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Nov 20, 2008 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Water filter
are you looking for a replacement filter for your refrig or looking to locate its whereabouts in refrig???? 11 years ago its possible, sorry very probable that a water filter did not come equipped with refrigs.if so it would be in top right corner mounted on ceiling insider refrig.
Mar 11, 2008 | GE Profile TPX24PBDCC Side by Side...
Refrigerators Logo
89 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
