Question about Char-Broil Patio Caddie Grill
Charbroil patio Caddie gas grill. Push button ignitor does not work. Should we replace the ignitor electrode? Or something else?
4 Suggested Answers
skyblue67
  • 71 Answers
SOURCE: i need a manual for a char-broil patio caddie gas
Hello I found this site by the suppliers of your gas grill, you can buy replacement parts etc for your grill if needed and they do have user manuals, hope it helps
http://www.charbroil.com/
Posted on Jul 24, 2009
radar001
  • 1051 Answers
SOURCE: Use of Charcoal or Lava Rocks in the Char Broil Patio Caddie?
LP grills are designed to use lava rock ONLY. Charcoal will clog the burners.
Posted on May 16, 2010
TheMobilian
  • 8220 Answers
SOURCE: I would like to purchase a new manual for my
Manuals for Char-broil Caddie type grill
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 30, 2010
Vermont castings grill cf9055, not lighting
I would look for spider webs in the burners .or that the ignitor is not close enough to the gas coming in
Jan 09, 2018 | Grilling
Plastic knob on regulator is cracked causing gas leak where it attaches to LP tank. Needs replacement. Can I get a regulator/hose?
Hi kimandjimm...
You can use any generic hose and regulator assembly for your grill.
You can buy it online at: http://www.appliancefactoryparts.com/gasgrillparts/brands/charbroil/charbroil-plumbing-valves.html
You can buy them at HomeDepot,Lowes,Ace Hardware,etc. Look in the grill section.
Please take time to rate me
Sep 07, 2011 | Char-Broil Patio Caddie 4654870 (LP) Grill
I had to change the burner but now the igniter will not automatically ignite when pressing the button. What should I do?
The piezo ignitor head my need to be adjusted so that it is closer to the burner. If it is not sparking at all, check for a loose wire at the piezo ignitor and trace it back to the ignition button. Often times, it will simply lost it's ground. To resolve this, carefully pull the ignitor wire off the piezo pin and the push it back on. Do the same thing on the back of ignitor button.
If none of the above solves the problem, it's time to replace the ignition systems. The parts are inexpensive and can be purchased on-line directly from Char-Broil http://www.charbroil.com/Store/ReplacementParts.aspx or from any home center or hardware store that sells gas grills and accessories. These will be universal fit model ignitors .
Hope this helped you. Please let me know. Thanks.
May 31, 2011 | Char-Broil CharBroil 4637318 Grill
Need to purchase replacement regulator/valve (one piece) for patio caddie grill??
If what you're looking for is the Regulator/Tank Hose Assembly, you can purchase that for any home center or hardware store that sells gas grills. They are pretty much a universal fii, but be sure to take your old one with you for comparison purposes of the hose length. A little longer is ok, but shorter is not.
If that's not what you're looking for, you can purchase replacement parts directly form Char-Broil.
Happy Grilling!!
Mar 30, 2011 | Char-Broil Patio Caddie 4654870 (LP) Grill
Does the patio caddie use any kind of charcoal or lava rock
Your model Char-Broil LP Gas Grill use Lava Briquets on the lower grate above the burner(s). Any generic type will work. Just space them in evenly on the grate in one layer. You'll probably have some left over. So store them in an airtight container for future use (replacement).
Jan 26, 2011 | Char-Broil Patio Caddie 4654870 (LP) Grill
My grill won't light. I have new propane and when I turn it on and push the button it clicks but no flame. Any suggestions? Thank you
First thing can you hear and smell propane running. If you can then try and start with a match. If this works your ignitor is probably dirty in the grill area. Where wire connects under grill look at the metal that this is connected to, could be dirty with grease or just needs to be bent closer to metal that it sparks off of. If this doesn't work then ignitor button is bad and needs to be replaced. You can buy at lowes or home depot.
Jun 13, 2010 | Char-Broil Patio Caddie 4654870 (LP) Grill
Does the Char Broil PAtio caddie come with bricquets?
No, it does not. Here is the complete parts list for your patio caddie:
Patio Caddie Parts
  • Electric Patio Caddie Heating Element
$22.00
  • Patio Caddie Ignitor Electrode
$4.19
  • Patio Caddie Burner Shield - Heat Distribution Plate
$10.75
  • Single Pole Snap-In Ignitor Push Button
$5.25
  • Patio Caddie Ignitor Wire
$2.50
  • Patio Caddie Top Lid Handle
$10.50
  • Patio Caddie Hardware Kit
$8.15
  • Electric Patio Caddie Aluminum Top Insert
$37.50
  • Electric Patio Caddie Aluminum Bottom Insert
$37.50
  • "Grease Catcher" Hanger Wire and Cup
$4.50
  • Patio Caddie Cooking Grate
$29.00
May 17, 2010 | Grilling
May 16, 2010 | Char-Broil Patio Caddie 4654870 (LP) Grill
Char broil patio caddie, how many coals should it contain?
Your referring to the 'LAVA ROCK' which lines the botton grate. There should be enough to cover the grate 1 layer deep only.
Apr 27, 2010 | Char-Broil Patio Caddie 4654870 (LP) Grill
I need a manual for a char-broil patio caddie gas
Jul 24, 2009 | Char-Broil Patio Caddie 4654870 (LP) Grill
Char-Broil Patio Caddie Grill Logo
110 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Jim Thurston
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
