Question about Dell Inspiron 1520 Motherboard
I recently had my motherboard replaced by a Dell technician due to video problems. Ever since it was replaced I've been getting blue screen errors saying Hardware malfunction, random sudden restarts, and random freezing. Is this being caused by the new motherboard being installed improperly or a faulty motherboard?
    President:
  • 2,571 Answers
If this happened after the dell technician called, ring back and complain, if your not happy with the result, i would talk to an advice orginisation. In the UK we have places like the C.A.B. ( Citizens Advice Bureau )
Posted on Aug 03, 2010
Dell Dimension 3000 blue screen error with writing that say attemp to fix windows
First of all you have to identify the blue screen error code. Blue screen errors normally occurs due to infected windows files. You need to scan PC to remove malwares, junk and virus.
Also update the drivers that control your PC.
To fix this problem instantly use system optimization tool like Reginout.
Mar 27, 2013 | Dell Dimension 3000 PC Desktop
Dell Latitude D610 Intel M Blue Screen Error - Technicians Help!? Hey I?m getting this Blue Screen Error msg for the fifth time with exact same error (DRIVER_IRQL_NOT_LESS_OR_EQUAL bcmw15.sys ? Address...
I have had Dell hard drive pass Diagnostic test before and still needed to be replaced. System worked fine after the replacement. At this point, with so much of your time invested I would swap out the HD. The next highest probability for the source of he problem would the motherboard. But I would go fo the HD first.
Good luck.
Nov 18, 2009 | Dell Latitude C610 Notebook
Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Oct 16, 2009 | Dell Inspiron 1520 Motherboard
Dell blue screen of death
posting the stop error code and what you are doing when error occurs would be helpful. If you are getting blue screens and have pixelation of video, artifacting or other Video weirdness, then you may have a defective motherboard. If you have video corruption, and the system is in warranty or if the warranty has expired in the past year, contact Dell tech support for a motherboard replacement.
Sep 30, 2009 | Dell XPS M1330 Notebook
Dell Dimension 5100 with Video distortion
Back everything up hurry there is no easy fix for this an OS re-install may help but you need to back everything that is your personal files up don't back up any system files just your docs, pics, and restore the machine your LCD panel could have a problem also
Sep 21, 2009 | Dell XPS M1210 Notebook
Gx270 dell During istall of OEM XP I get blue screen codes 24,8,&
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 41f927c.jpgd3990ed.jpgALL these systems suffered from defective capacitors caused by bad manufacturing at the component factory. I have put here a pic or two for you to see what defective caps look like. Call Dell and ask them. I some case a while back they were doing a free motherboard replacement. The problem causes a whole raft of errors to occur from blue screens to "thermal event error" and the only thing that fixes it is to have the motherboard replaced. Hope this helps you
Kind regards from London
Mark
Aug 25, 2009 | Dell Optiplex GX270 Intel Refurbished...
Dell Inspiron 1525 Blue screen & windows error messages/reformat
Do a recovery first and if you are still getting a blue screen on this 1525 call dell and ask for a replacment do not go any further in trying to repair it yourself as anything you do would just make matters worse if its out of warrenty then the only thing you can do is try:
1. clean the unit if there is any dust
2. try new memory modules
3. run a memory diagnostic on it using windos diagnostics
4. recover the operating system.
I hope you have some good luck with this advice.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Dell Inspiron 1525 Notebook
I have a dell dx280 when I start the pc. I can see some simbols in the bios screen, after that I try to install windows xp and in the process appear a blue screen with error message about hardware problem....
First refix RAM memory . then try to install windows xp 5 times untill you can.
i also face same problem it is due to memory related so i refix RAM and try winxp install 3 times and i succeded.
Jul 16, 2009 | Dell Optiplex GX280 (99301) Motherboard
Dell Dimension boot problem
You could try uninstalling the Display Adapter driver from Device Manager while in Safe mode then see if you can reboot normally. The drivers may reinstall automatically and it might blue screen again. If prompted to install drivers when restarting you could cancel and attempt to find better drivers, but it may be a failing video adapter.
Nov 20, 2008 | Dell Dimension 8200 PC Desktop
Dell Inspiron 1520  Motherboard Logo
78 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
