Question about Imperial IFS40 Deep Fryer
Pilot light will not stay lit as soon as you let off the gas valVE arm it will go out. vulcan model TK 65
  • 77 Answers
1. Check to make sure you have continuity across the high limit terminals.( you can use a jumper wire for testing) Unit operates on about 1/2 of 1 volt so no worry of a shock. 2. Check to make sure your pilot generator is producing over 500 millivolts. Make sure the pilot orifice is clean and that you have a nice sharp pilot flame heating the pilot generator.
Tom
Posted on Aug 16, 2010
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
How to light the pilot light on a natural gas wall heater
SEt to pilot, Push knob, push pezio ignighter until pilot lights, hold for 30 seconds. if it stays lit turn to on, if it doesn't stay lit, you have a bad thermocouple
Mar 24, 2011 | Vulcan Heating & Cooling
Can't light a vulcan heritage gas heater, the pilot light lights, but as soon as I try to lift my finger off the button to ignite the heater, the pilot flame always goes off.
Hi and welcome to FixYa, I am Kelly.
What you are experiencing is the lack of a signal from the thermocouple to the gas valve. I.e. the thermocouple is not passing heat information at all. This is caused by either a defective thermocouple, a dirty mating area where the thermocouple connects to the gas valve or... an improperly positioned thermocouple that is not "in the flame" with the pilot lit.
  • First make sure the FIRE end of the thermocouple is in the flame when lit. (reposition if necessay)
  • Next disconnect the thermocouple by unscrewing the fitting on the top of the gas valve. (No gas will come out) Clean the metal mating area as best you can and then re-install the thermocouple. Just a good snug fit. Once you feel it come snug add 15 degrees of tightening motion with a wrench.
Attempt to light the pilot... wait 45 seconds to 1 minute while holding the pilot button down before letting it up. If it stays lit.... GOOD JOB. If it goes out the next step is to replace the thermocouple. If after replacing the thermocouple it does not stay lit the remedy is to replace the gas valve. There are no short cuts and the sequence of repairs is just as I stated in order.
You can remove your old thermocouple and walk in to almost any appliance parts supply or Plumbing and heating supply to purchase the correct thermocouple without a part number. They will match it up with yours.
Thanks for choosing FixYa,
Kelly
Feb 20, 2011 | Heating & Cooling
I have an old Vulcan 6 burner commercial gas stove with a 24" griddle. The gas was turned off during a remodel. Now the gas is back on and the gas burners work fine but I cannot get the oven pilot light to...
Hi- This should have a gas Safety Valve, this is the main valve to the oven (this probably has 2). If you remove the lower panel under the doors they are probably right there. Looks like a large gas valve with a button on it, sometimes the button is red. You need to hold in that button while lighting the pilot and keep holding it in for a few seconds until the thermocouple gets hot enough to tell the valve to keep the pilot on. You'll have to do this for both ovens if there are 2 valves. It's possible the valves are located somewhere else on the range so you may have to hunt a bit. If the pilots still won't stay lit you may need new thermocouples in which case I'd call a Tech out to look at it. Hope this helps. Good Luck.
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
I HAVE A DESA LP VENTLESS FIREPLACE AND THE PILOT WILL NOT STAY LIT
the heater makes use of a millivolt generator which generates a small dc voltage (500-750mv) that is applied to the pilot valve of your main gas valve. when you light your pilot, the flame bathes the generator with a flame. after a delay you release the pilot button. if the generator is working, the pilot valve will stay lit. if the generator is not working the flame will go out as soon as you release the pilot button. change the generator.
Oct 13, 2009 | Desa International Heating & Cooling
Pilot light keeps going out on one side of my Tappan stove (TPF303BWA). The 2 left burners are fine but the right side burners will not stay lit. I can light them with a match and they stay on for...
HI, Try using a needle to clean out the pilot orfice. Most models have an adjustment for the pilot light. It would be located near the manifold under the top panel.
I hope this helps you. Please let me knwo if I can assist you further.
Vic
Jun 05, 2009 | Tappan TGF303BW Gas Range
Oven pilot light will not stay lit
The thermocouple is bad this is the probe that sits next to the pilot,the pilot flame heats the thermocouple and then it sends a micro voltage to the valve to keep it lit.Goto hobartcorp.com and find your model then the part number.
Sep 04, 2008 | Vulcan 60L Gas Kitchen Range
Imperial IFS40 Deep Fryer Logo
230 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Joseph Hoffmann
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
