Diagonal green lines on a green screen
My CRT TV (PAL) goes completely green with green diagonal lines (like a diagonal continuous scribble) as soon as I switch it on. After about 10 minutes I switch it off and on again. At this point the lines go and the picture is clear. It happens every time but is now beoming more difficult to get working as more often than not the screen goes back to green. The funny thing is that once the screen becomes normal it stays like that until it is switched off again. What can I do to resolve this problem? I opened my TV (A Daewoo 28") and found the tube to be made by Philips.
    Genius:
  • Televison & ... Master
  • 1,673 Answers
It is possible that the electron-gun inside of the CRT is having an intermittant short. It is also possible that there is an intermitttant failure in the bias or drive circuits for the CRT electron-gun.
The TV service tech would have to run some tests to determine the actual fault, and then the failed components.
If the CRT is at fault, the set will not be worth to service.
Jerry G.
Posted on Apr 25, 2008
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
Sony 42" - green scribbles on screen
Check the four 1 ohm resistors on the 9-1690 convergence module.
Apr 13, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
New RCA TV just out of the box, show's nothing but green diagonal lines.
Recommend contacting the seller and tell them you are bringing it back and why.
Mar 05, 2015 | RCA L42FHD37 42 in. LCD HDTV
Why does my rca guide plus gold gemstar tv have lines or bars flickering on the screen ?
are they horizontal or diagonal? if they are diagonal it could be you're brightness is turned up too high. try turning it down.
Aug 13, 2012 | RCA F36705 36" TV
Diagonal lines in picture
Diagonal lines are usually called "retrace" lines and are caused by a issue on the CRT board or the master screen being set too high.
Jun 26, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
The tv comes on and then goes completely out after about 20 sceonds. While it is on there are diagonal lines on a lime green field that do not move.
yes. if you have a black bright screen with about 16 to 20 horizontal lines going across, you have no video. suggest local service center. if it is a magnavox, this is easy. you have an open 1 ohm(approx. value) resistor on the crt board.
Nov 12, 2009 | RCA Televison & Video
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Diagonal lines through the picture of Samsung DLP set.
Hi
where the line is coming out? from left to right of your screen or bottom to top?
Thanks!
Dec 27, 2008 | Televison & Video
GREEN VERTICAL LINES
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
Electro Med Services...
