Question about Goodmans CD / MP3 car radio GCE780MPT CD Player
IVE MISLADE WIRING& PLUGS FOR CAR CD GCE2813PLL
Hi i need some help i have a sub and amp in a ford fiesta 2001. ive chanced cd players to a ridspeed dv720. my sub was working fine with my old cd player but now ive put the ripspeed in it doesnt work. i...
You can use a "Y" cable to combine the two RCA cables to the one out. You will need a 1 male to 2 male cable. That will solve the signal problem. Is the amp functioning properly. I would check that first. Make sure your wiring is correct. Hope this helps
Aug 25, 2011 | Car Audio & Video
Ive got a kenwood kvt-512 n im tryin to hook an amp n subs up but dnt know where to plug my RCA jacks from the amp 2 the radio!
Your unit should have 2 plugs in the back...one for the audio and power wires to connect to your factory connections and the other plug is just RCA connections for your video, subs and front speakers. If you have a 4 channel amp and a amp for your subs, you will have to split the 4 channel amp down to 2 and run them to your front RCA connections. Subs will connect to the sub connections. If yours are not listed then you may have to track down a wiring diagram. Hope this helps.
Jun 12, 2011 | Kenwood KVT-512 Car DVD Player
Were is the sub woofer tie into at.
You should have two (or more) RCA plugs on the back of the deck that will act as pre-amp outputs for subwoofer and speakers.
Failing that, your wiring harness should have come with a wiring diagram that will let you know which is the subwoofer output.
Failint THAT, the deck itself should have a wiring diagram on the bottom or side telling your which wire is which.
And if that fails, Your deck may not have a subwoofer output. Just attach your sub to the amp pre-out like everyone else.
May 11, 2011 | Pioneer DEH-2400F CD Player
I am looking for the wiring diagram for the 1998 Nissan Terrano 2 (AU) I am fitting a Sony xplod. The original Nissan plugs already removed. Just the wiring of the Nissan at the head unit would be fine as...
hope this is of some help its for the patrol, the wiring is virtually the same
http://www.pdfee.com/1998-nissan-patrol-y61-electrical-wiring-diagram-service-and-troubleshooting.html
Mar 18, 2010 | Sony XPLOD CDX-GT200 CD Player
I need the wiring diagram for my new Clarion dxz385usb
Brown wire-Phone mute Yellow 3A-Bus power lead Yellow 15A-Memory backup lead Red-Power lead Blue/White-Amp lead Black-Ground Orange/White-Illumination lead Blue-Auto antennae SPEAKERS(black strip is -ive) gray+gray/black-front right white+white/black-front left purple+purple/black-rear right green+green/black-rear left
Jul 02, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
My amp works but something is wrong with the wiring or something.
there is a loose connection on the power supply going to your amp,check the fuse holder
Jan 07, 2009 | Car Audio & Video
Sony car cd player help!
Run a temporary direct power line to battery and see if it will turn on
Aug 08, 2008 | Sony Car Audio & Video
Sony xplod xm-554zr amp
if you are trying to run some highs with built in high-pass crossovers off of a amp that is setup for subs(amp is on low-pass) then your highs will not work. You are better off running another amp or running them off of your deck...
Aug 18, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Goodmans CD / MP3 car radio GCE780MPT CD Player Logo
Top Goodmans Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Goodmans Car Audio and Video Expert? Answer questions, earn points and help others
