Question about Toshiba Satellite P305D-S8834 Notebook
I have a Toshiba Satelitte P305D-S8834 lap top computer. And am experiencing Unexpected shut downs. when trying to restart; the first attempt it will try to restart then shut down again, second attempt I get the start normally, safe mode screen, then third attempt I get windows detected start up problems, would you like to repair/restore. After going through the start up repair, the computer comes back on and stays on. This has happened a dozen times in the past three weeks. Do you have any idea what may be causing this problem? I searched the Toshiba support and found others were were experiencing shut downs, although none of them listed that they were being taken to the start up problem page when shutting down. Most of the answers that were given them was that the computer was over heating. Please Help Thank You Lloyd Putman
    President:
  • 2,571 Answers
Usually you will get shutdowns through Virus/malware infection or overheating.
For overheating, clean out the fans/heatsink
For infection http://www.fixya.com/support/r5272277-secure_clean_computers
Posted on Aug 03, 2010
Screen is black. Power button lights up, fans and DVD seem to work.
hi there,
What you are experiencing with your laptop is "POST" (Power-on self test) issue. Here are some steps which you can try.
- Remove the battery and ac adapter (as well as external peripherals attached), press the power button for atleast 15 seconds, try to power on your computer again.
- If you have external monitor, hook it up. Display on the external monitor would mean that you have a LCD issue (check LCD cable, LCD inverter and LCD backlight in this case). No display on the external monitor would mean that you need to replace the video card (if dedicated) or replace the whole system board (if integrated).
- Try to reseat or replace the memory module as well, it might help.
Regards.
May 10, 2011 | Toshiba Satellite P305D-S8834 17 in Laptop...
My Toshiba satellite P305D-S8834 will not turn on. It was not dropped. I opened our lab top and it would not turn on. I push the power button and lights come on with the power switched an indicator lights....
More an likely its your LCD. If it powers up and you are getting a hard drive activity light then that points to your LCD, could be a damaged backlight or inverter.
Apr 11, 2011 | Computers & Internet
Battery will not charge the new one and old one
Goodday!
if your computer has still warranty, i much prefered to check it to the service center of toshiba.
Thanks!
Mar 21, 2011 | Toshiba Satellite P305D-S8834 Notebook
Can I install a better CPU into my Toshiba Satellite P305D-S8834 17 1 Widescreen Notebook Computer then the AMD Turion X2 Processor RM-70 it came with?
Changing CPU is a serious change. When your unit was built the processor speed and type were written into the BIOS. When we change the CPU to a different type there is a chance that the BIOS will not recognize it and refuse to boot up. Also Windows was installed with the original CPU and a major change in hardware could mess up Windows.
I did some research and found this model comes with a 2.0-GHz AMD Turion X2 Dual-Core RM-70 CPU and 4GB of RAM. This is not the fastest CPU that can be put in a laptop but a very good one. (faster than mine)
I can guide you through the steps to replace it but my advice is stick with what you have until it breaks and buy a faster laptop. The upgrade won't gain you enough to justify the expense.
May 21, 2010 | Toshiba Satellite P305D-S8834 Notebook
After booting up the lap top shuts down after about twenty seconds ????
when your computer is booting up continuously keep clicking the F8 button until a selectioN of options appears on the screen ,then select the option " last good configuration" and click enter , This should sort reconfigure your laptop.
Mar 26, 2010 | Toshiba Satelitte P35-S605 Notebook PC
I just installed vistas ultimate on the satellite p305d-s8834 and now I cannot detect any network devices/hardware. The laptop did not come with any recovery discs. can I download the device or is there...
Hi, lets restore your ("systems configuration"), by doing the following: From the Start Menu, Type: Toshiba, in the "search box." Next find the Toshiba Application Installer, if your computer have this "Function?" it would make the process alot easier; open the (TAI), and click next, you can select from different Drivers to Install, click to (highlight), click on the install button. "It is hightly recommend to restart the computer, when finished!" "Did this solution help?"
Jan 30, 2010 | Toshiba Satellite P305D-S8834 Notebook
My drivers don t launch evry restart
Kindli go on This link
toshiba driver site
https://www.toshiba-india.com/DriversDetails.aspx
Give your notebook modul No And download your driver (its free)
Nov 19, 2009 | Toshiba Satellite P305D-S8834 17 in Laptop...
Hi, I have a P305D-S8834, daughter left it on the bed on and when we came back it would no longer boot up, only lights on the base, nothing on lcd, I replaced the motherboard and still the same. Any ideas?
Probably burned struff up ... on the bed the computer cannot get vital cooling air because the covers blocked the fan suction.
If this is the case, you have a parts computer. Dont try to fix it.
Oct 07, 2009 | Toshiba Satellite P305D-S8834 17 in Laptop...
My toshiba wont start it keep's restarting at the black loading screen.
have you done a maintainance on it to get rid of all the excess information?? if not..go to start--then all programs, then accessories, then tools, click on disk cleanup. click on yes to all when the pop up box show up.
after this do a defragmentation-- go to start, all programs, then accessories, then tools, then disk defragmenter. click on analisys-- this will tell you if you need to defrag your system. if yes-- do it..it will take time to defrag, but it will speed up you game play ability.
Oct 13, 2008 | Toshiba Satellite P305D-S8828 Notebook PC
My problems is i have toshiba lap top my cousin was messing with it now all it says is.the computer restarted unexpectedly or encountered and unexpected error.windows installation cannot proceed. to...
I have two Toshiba lap tops, I had the same problems which you have, tell you the truth, I took them to Bevely Hills factory warranty shop changed the mother board and then after eight months, I had some other problems, total five times in the repaire shop and finally passed the warranty. It is totally gone.
I know this can not help you at all, remember four years ago, Toshiba been suit, finally I got two years factory warranty for my lap tops, I wasted too much of my time to solve the problems but both lap top I can not use anymore,
Jun 22, 2008 | Toshiba Computers & Internet
Toshiba Satellite P305D-S8834 Notebook Logo
237 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
