Question about LG 19 Widescreen LCD Monitor, 1440X900 WXGA+, 10000:1, 2ms, 300 nits, VGA, DVI, Black 19 inch
My monitor :LG 19 Widescreen LCD Monitor, 1440X900 WXGA+, 10000:1, 2ms, 300 nits, VGA, DVI, Black 19 inch. I recently turned it on to start work and it noticed as it was going from the loading screens to log in, on each one you would only see the picture for about 1/4 of a sec each then it would go black. You can still her sound and the light on the monitor is blue( saying its on. When you turn it off via the switch on the monitor and back on again, you can see it for 1/4 of a sec then it goes black immeidiatly.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 20 Answers
Sounds like your video card is dead ... without computer Specs can't tell you what video card to get but your local computer shop can fix for you
Posted on May 18, 2017
  • 16 Answers
SOURCE: 17"LCD Monitor
This problem is showing when the main PCB of the monitor failed. Contact the LG service provider in your area.Check this link to get the service center info
http://www.lgservice.com/
Posted on Feb 09, 2008
SOURCE: Hannspree 19" Widescreen resolution available
I have the same problem. i downloaded a generic driver that allows 1600 X 900 resolution. this is better..things are taller rather than wider (with the 1280X1024 resolution). i dont understand why there isnt a 1440X900 driver available for XP systems.
Posted on Jul 31, 2008
  • 133 Answers
SOURCE: I have samsung 19
ok sanjayji, first go to ur desktop > then right click on an empty space > go to properties > then settings > then at the lower left side u can see "resolution"
and there u can set your resolution to 1440*900.
hope this helps.
please gimme accha rating.
Posted on Mar 25, 2009
prashanthcl
  • 460 Answers
SOURCE: LG W1934S monitor. It displays an image for about
first you ensure that it is a problem with TFT or CPU. you can check it with another monitor. if it is working with another monitor then your TFT has been faulty.then you can repaired it from service center.
Posted on Nov 04, 2009
Testimonial: "Good direction for me to persue."
  • 1684 Answers
SOURCE: lg monitor. Turns on but screen is white
This is a common problem on LCD monitors after a few years of use. Because of heat buildup in the monitor case parts called capacitors have started to blow out. When they blow they cause the power supply to fail and not provide the correct voltages the unit needs. If you go to our site at :
www.ccl-la.com we have pictures of what the blown capacitors look like. Open the back of your monitor and look for the blown ones. If you can solder then you can do the repair yourself. Unsolder the bad ones and install new ones. You will need Qty 2 1000uf 16volt and qty 3 1000uf 25 volt capacitors.We have a parts kit for $12.00 I will post a step by step repair guide for you on 11/29/09. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions please contact me at below address.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Nov 29, 2009
I need lg flatron ips234 led datasheet
you can get a manual here
http://www.lg.com/uk/support-product/lg-IPS234V
or here
http://www.manualslib.com/manual/415946/Lg-Ips224v.html?page=12#manual
May 31, 2014 | LG Flatron IPS231B-BN 23 LED LCD Monitor -...
Hyundaip90wu screen flicker
Unfortunately, unless you are an electronics expert, getting this fixed may cost you more than getting a new monitor. If it is under warranty, contact where you bought it. One thing you could do is try this monitor on a different machine, but I think it would still flicker.
May 02, 2014 | Hyundai P90WU 19" LCD Monitor - 5 ms 1440...
2nd monitor does not work with DVI to VGA converter cable. My video card has VGA and DVi ouputs.
The problem could be in the adapter to the video card. There are different types of DVI connections. If the adapter does not have the proper set of pins then the card will not recognize that a monitor is connected at that port. Monitors themselves have no bearing on whether a single or dual monitor set up will work or not. Digital Visual Interface Follow this link, it may help you determine if the adapter you are using is correct for the graphics card.
Apr 22, 2014 | Acer ET.CV3WP.E05 LCD Monitor - V193WEJb...
I have a 19 inch Gateway HD monitor. The model number is LP1925. When I boot up everything is normal. However, after about 5 minutes the screen goes black. I can't get the picture back unless I pull out...
I see that this monitor has a DVI input, in additon to the VGA input. I suggest getting a suitable cable to use the DVI input, to see if the fault replicates. If it doesn't, you have identified the problem - an issue with the analogue signal processeing circuitry in either the monitor or the computer. The monitor's auto sleep analogue circuitry, for example, may not be sensing a signal, and going to sleep. BTW, if you use a DVI-DVI cable, you avoid the video signal ever going through an analogue stage, and the image will also be purer.
Dec 16, 2017 | Gateway 19" Widescreen Flat Panel TFT LCD...
My montor is going green in place how can i fix it
move the speakers away from it the magnet is pulling the color out of the screen :)
Jan 27, 2010 | LG 19 Widescreen LCD Monitor, 1440X900...
Monitor resolution
What do you mean that you were unable to get the native resolution of 1440x900? Are you saying that the resolution varries?
Since you mentioned that the mother board supports 1440x900, try to set the monitor resolution to that same resolution and then restart the computer.
If you will get the same problem, you have to make sure that the video card supports 1440x900 resolution.
Apr 15, 2009 | LG L194WT 19" LCD Monitor
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Jul 30, 2008 | Hannspree 19" Widescreen LCD Flat Panel...
LG 19 Widescreen LCD Monitor, 1440X900 WXGA+, 10000:1, 2ms, 300 nits, VGA, DVI, Black  19 inch Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
