Question about Dell IN1910N 19" Monitor
My Dell monitor worked fine last night and today the computer starts up fine but the monitor goes to auto detect and then goes into safe thing , I checked all the wires and such and they are fine but I can get the monitor up and running to be able to see to go in and make corrections. All I used th epc for is email, typping, and ebay. Please help me I am so lost
  • 4,323 Answers
Hi
The issue can be with the monitor or can also be due to an issue with your PC. You'll need to check for any disconnections from your monitor to pc. Make sure that the connector to the monitor is fine and all the pins are intact. If the above things are fine then it is an issue with the PC's Video card. To be sure you can try connecting a laptop/another monitor with the desktop to confirm if its an issue with the Video Card or monitor.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 03, 2010
  • blastfurn900 Aug 03, 2010
    Thank you so much, I plugged in my friends laptop and my monitor instantly came to life so it must be the video card. Now if I only knew how to put one of those in. i know where I can buy one but is it difficult to repair, I would like to do it on my own because I am laid off currently and cannot afford to pay someone to do it for me. Thanks for your help!
My computerr was working fine last night I turned it on today and dell media home came up then it goes to a blue screen that reads a problem has been detected and windows has been shut down to prevent...
Driver or software update that was incompatible can cause this, try to boot to F8 and run a disk check.
Also failing ram can cause this, check the ram modules using Mem test
Dec 30, 2010 | Dell Inspiron 1525 Notebook
I plugged my LG flatron into a dell x150. I can see up till Windows starts booting and then it cant read the signal. The dell works fine with a old sony monitor not sure why. Flatron works with every other...
If you would start the Dell in safe mode, you should be able to adjust the display settings to values that will work with the monitor. Or remove the monitor in the device manager and let windoze detect and configure the monitor on the next boot.
Nov 12, 2009 | LG Flatron L1510S 15" LCD Monitor
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Intermittent monitor blackout
if you check key board caps lock or num lock keys, also on aond off (LED in Caps and num lock)
you have check the video card , pls go to safe mode and test the problem
also need the check monitor with another pc
Sep 12, 2017 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Monitor display is pinched at the corner
Check if the same thing happens under safe mode.
Safe Mode
Continue to press the F8 key when Windows starts to load
Or hold down the CTRL key
From the menu, select Safe Mode
Same thing? Then I have bad news for you. You need a new monitor. Best to verify for sure on another computer though.
Jan 17, 2009 | Dell Dimension 3000 PC Desktop
Starting up
If you haven't fixed this problem yet; try to start the system in Safe Mode by tapping on F8 when it's booting up. When asked to start in safe mode or normal, select Safe Mode.
Your graphics are going to be bad when you do that, but if that works let me know. then you'll have to go and change some settings
Dec 13, 2008 | Dell Inspiron 6400 Notebook
Dell LCD monitor quickly goes sleep, on, off over and over
I would recommend that you try it on another computer to see if you are able to reproduce the results. If that is the case you should look at any new drivers, software or updates that have been installed. If the issue continues with another PC, it sounds as though the monitor's power supply is possibly failing. in that case I would suggest you simply replace the whole monitor. Unless you are not shy with a soldering iron. ;) good luck!
Nov 19, 2008 | Dell E197FP LCD Monitor
Using windows xp with regular updates for 4 years no problem. today will not start. tried F8 to safe start and none of the options work screen goes blank
HI,
The last thing you can try is hit F8 again and select "LAST KNOWN GOOD CONFIGURATION"
If you still face the problem then you will have to install your Xp again.
Sep 27, 2008 | Computers & Internet
Over range auto detectable flashes across screen
Restart the computer in safe mode by tapping the "F8" key as it comes on. Then open display properties and set the display settings to a lower setting and restart the computer.
You
Jan 04, 2008 | Albatron L17AS 17" Flat Panel LCD Monitor
Dell IN1910N 19" Monitor Logo
22 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
