Question about RCA P52960 52" Rear Projection Television
TV losses power comes back on after tapping the side???????
  • 1,557 Answers
I would say it has a dry solder joint. it needs to be looked at by a tech pro to find and re solder the point.
hope this helps
Posted on Aug 03, 2010
Phillips 52pfl5704d turns on screen blinks, no video
The replacement board could be defective. Your TV worked fine until there was a power loss so its time to troubleshoot to find out how the power loss affected the original board in theTV. There could have been a power surge.
Dec 12, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hi my Samsung plasma tv turns off randomly after 20 min ,1 hour ,5 min and sometimes you can tap tap just above the power input and it comes back on
my tv do the same thing, it's my power cord, check and see if it's
loose where it plugs into the tv, if yes that's ur problem if not don't know
Jan 16, 2013 | Televison & Video
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
TV comes on stays on for a short time than goes black with loss of sound green flashing light untill TV comes back on. takes maybe 2 min.
Jul 11, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
My tv goes off by itself, after a while it comes back on. two days ago it went off and i cant get it back on
There is an IC in the TV that controls all functions; power on\off, volume, menu functions, etc.
When this IC losses power it will turn off the TV.
When this IC regains power it will restore the TV to the last Known condtion before the power was lost (OFF or ON)
It is possible that this IC is defective and has intermmitant power or functionality. This would result in this intermittant off and on and why you cannot power it on suddenly.
Also, be aware if the outlet that the TV is connected to losses power you could get this symptom (same if the outlet has a loose connection with the TV power cord)
overall point is:
1. Ensure the wall outlet is in good condition and the TV
2. the TV power supply could have some issue
3. if not 1 and 2, the TVs main board may be defective.
Jun 22, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
PICTURE IS NOT ALIGNED HAVE TO TAP TV TO GET IT CORRECTED
since you have mentioned that you first tap the tv set for it to work well, it has obviously loss connection/ cold solder... check for cold solder and reheat it, this will solve your problem...
Sep 28, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Phillips 42 inch Plasma -Screen Issues!!!
intermittent loss of picture on either bottom or top half of screen is specific to y buffer boards located on left side of screen going from top to bottom when looking at back of tv. the y lower buffer would be the board to replace to resolve the loss of bottom half of picture. if the top half also is going out intermittently could tied to upper buffer as well but just a note the y main board to right of these buffers drives those two boards so in some cases could also be part of the problem. if only bottom half is affected i would recommend replacing lower buffer only
Aug 07, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
What`s seems to be the porblem
IT SOUNDS LIKE THE VERTICAL I.C. NEEDS SOLDERING. WHEN IT LOOSES THE PICTURE DOES IT HAVE ERROR CODE 2 ? THE RED LED BLINKING 2 THEN 2 THEN 2. THAT IS LOSS OF VERTICAL. IF YOU SMACK THE SIDE OF THE SET.(NOT TO HARD) WITH OPEN PALM ON LOWER BACK IF THE PICTURE COMES BACK IT IS THE VERTICAL IC THAT NEEDS TO BEE SOLDERED.
DON.
Jan 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCA P52960 52" Rear Projection Television Logo
22 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
