Question about Sony PlayStation 2 Slimline Console
Swap Magic Problems
What is tool 1? Where exactly is this small square hole? Have you got a picture or a diagram of what you are talking about? What you suggest i must do? Why after installing the Flip Top Cover it was spining and after putting the backup DVD-R it stopped spining?
Clicking on http://www.mod-chip.com/Lite/Magic_Key_2_PS2_Install_Lite.pdf took me to www.mod-chip.com. I went to http://www.mod-chip.com/Lite but i didn't find Magic_Key_2_PS2_Install_Lite.pdf!
Please try to be more helpful.
  • eagle338
    eagle338 May 11, 2010
    Please dont rate the posts negatively if you want more assistance.. its actually better not to rate till the problem is solved.. For now SAYONARA!
  • 4,889 Answers
Well .. i have changed my mind and thought i will help you.. can you tell me if the disc is spinning? If its not then try this..
The disk is not spinning because the flip top is not making contact with the sensors. Make sure the flip top is installed correctly. If the sensors are still not pushed down, boot up the swap magic disk and GENTLY put pressure on top of the flip top and see if the disk begins to be read. If it does, this means it is definitely the sensors. Like in my first post, open the ps2 and put a piece of thick tape over the rear sensor and a piece of tissue paper in the hole where the front cover opens. This will solve the problem.
Posted on Apr 27, 2008
What kind of tool do I need to remove the engine cover on a 04 LINCOLN Town Car? The bolt appears to be a square (not a hex)
I have a 2002 4.6L engine and it has a cover on it too. I believe I used a 1/4 inch drive extension to fit into the square hole. At the front of this cover you will find 2 slots that the cover hangs on with the top cover plug (with the square hole) providing the 3rd mounting point. You will need to slightly shift the cover forward after removing the top cover plug to clear the front mounting tabs.
When replacing the cover, you hang the cover on the front tabs first and then pivot the cover to align the mounting hole for the cover plug.
Jul 06, 2015 | Lincoln Cars & Trucks
Swap Magic Problems
TOC disk error normaly occurs when tool 1 of the set that goes in the small square hole at the front left of the drive bay above the power switch is missing or installed wrong
have a look at this
Apr 24, 2008 | Sony PlayStation 2 Slimline Console
I need help 2006 gran prix 5.3 serpentine belt ....... The belt broke and I can't get the new one on ......I can't get a socket on the tensioner at least what I think is the tensioner lol I need a sol
there is a tool that is used, i think with a long rachet and small extension you can do the belt, there should be a square hole where the end of the tool or extension goes into and then pull clockwise to release the tension, look closely at tensioner housing for the hole. i have enclosed a few pics of the tool and the tensioner. the picture of the belt diagram is there also, hope this helps.11_17_2012_9_08_07_pm.gif11_17_2012_9_08_21_pm.jpg11_17_2012_9_08_37_pm.jpg11_17_2012_9_09_07_pm.gif
Nov 17, 2012 | Cars & Trucks
Need to replace the serpentine belt. How do I do it myself?
YOU NEED A BELT TENSIONER TOOL BUY TOOL AT ANY AUTO PARTS STORE. JUST RAISE THE HOOD LOOK AT THE BELT TENSIONER YOU HAVE 2 SMALL SQUARE HOLES IN TENSIONER YOU HAVE 3/8 OR 1/2 INCH HOLE PLACE TENSIONER TOOL IN THE 3/8 HOLE ROTATE TENSIONER COUNTERCLOCK WISE TO REMOVE BELT. BESURE TO USE A LIGHT TO SEE THE TENSIONER HOLES.
Aug 29, 2011 | 1999 Buick Century
I want to play duplicate dvds on my ps2 but i am not able to do what should i do can i do it at home
  1. If you have backed up a game for ps2, you're going to need a mod chip or swap magic for your ps2 so it can read the disc, so first things first, BUY A MODIFICATION TOOL!!!
  2. 2You should try using Swap Magic, because it's the easiest, and you won't need to modify your PlayStation too much.
  3. 3But if you use SWAP MAGIC, you will also need a special mod chip, SLIDE TOOL, or a FLIP TOP COVER, you can learn more about those on the swapmagic website
  4. 4Read directions on the installation of mod chip, and swap magic before you do anything (you don't want to mess up, or else your ps2 won't work properly).
  5. 5Install your modchip/flip top cover/slide tool. (This is important, because it allows the disc to be removed and "swapped" without the PlayStation knowing).
  6. 6Follow directions that came with your swap magic discs, and you're basically ready to go!
  7. 7HOW TO USE SWAP MAGIC,Note you must have Swap magic 3.6 to boot on slimline ps2 and you need to do a none solder modding(no soldering)
Purchase a flip top (recommended). Let's assume you have the flip top and a copied ps2 game
  1. 1Now Insert the swap magic disc into the ps2,
  2. 2Press power on button until screens comes up.
    • With option that says load cd open the top cover of the flip top.
    • And take out the cd when it stops spinning.
  3. 3Now insert your Copied game and click Load CD.
  4. 4its that easy
May 30, 2011 | Video Game Consoles & Games
Hole in wall the size of a fist. How do I fill it and patch?
Follow these steps:
1. Useing a piece of scrap wallboard (same thickness has damaged wall) cut a square piece large enough to cover the hole. Place new piec over the hole and trace around edge of rteplacement piece. Cuit along lines with wallboard keyhole saw so that replacement piece fits perfectly. screw a wallboard screw into center of replacement (to act as a small handle) and coat edges of replacement with joint compound. Fit replacement into damaged hole and trowel compound to as smooth a finish as possible. Allow to dry completely the remove screw and sand to a like new wall.
Feb 24, 2010 | Square Mayes Level 10184 48" Wallboard ...
How do you get the serpetine belt back on?
if u have the diagram the rest is easy .you will need a racket or a loaner tool from auto zone put the racket n the tensioner hole a small square hole that wil move back and forth with some force
Jul 12, 2009 | 2007 GMC Yukon
Write a program to calculate Magic square Number A[4][4]
From Joe-Bob's handy-dandy reference:
(wikiedia...)
Normal magic squares exist for all orders n ≥ 1 except n = 2, although the case n = 1 is trivial—it consists of a single cell containing the number 1
The constant sum in every row, column and diagonal is called the magic constant or magic sum, M. The magic constant of a normal magic square depends only on n and has the value
13652227c2537f1018ce4d011d792db1.png For normal magic squares of order n = 3, 4, 5, …, the magic constants are:
15, 34, 65, 111, 175, 260, …
Feb 23, 2009 | Computers & Internet
Ps1 games
your slimline might not normally play the games Use swap magic it should have two discs one for booting PS2 games and one for booting PS1 games you simply put the appropriate swap magic disc and then the game you want to play
http://www.swapmagic3.com
This is what it states under What games support Swap Magic 3?
Swap Magic 3 support almost all SEGA ROMS, SNES ROMS, PS1 & PS2 Games!!
Feb 23, 2008 | Sony PlayStation 2 Slimline Console
Cardboard insert
It sounds like you may be talking about the wavegudie cover. Does it cover a square hole in the side or top of the caivty? If so, it is needed. It prevents grease and food debris from getting in the waveguide, which can damage the magnetron. I would refer you to Danby customer service: http://www.danby.com/page.asp?code=5
Aug 24, 2007 | Danby DMW1400 Microwave Oven
Sony PlayStation 2 Slimline Console Logo
96 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
