Question about Refrigerators
Wine cooler avanti model wcr683dzd,display show E1 end the compressor stop,how I fix. thank you
  • 57 Answers
Wine Chiller does not operate.
1. Not plugged in.
2. The appliance is turned off.
3. The circuit breaker tripped or a blown fu se.
If the character E1 appears on the digital display call service assistance.
Avanti Customer Service
800-220-5570
Posted on Apr 25, 2008
  • 4,102 Answers
Hi this means the compressor has over heated its best to switch of at mains for about an hour then switch back on and hopefully youll have no more problems if you do then the compressor could need replacing
  • paul proctor Apr 25, 2008
    Also check their is nothing causing it to overheat like anything dropped on compressor or near a heat source this should not be by any heat source as this will cause it to overheat.
    Switch off for an hour let it cool down then switch back on and just keep an eye on it you should find it will be ok but let me know if it gives same message.
    If the message comes on strait away after being off for an hour then their is a serious fault and the compressor needs replacing ok get back to me after this
    @ginko thanks for providing the info as i couldnt find the numbers anywhere so thanks for providing them and also the parts.
    ginko you know the compressor well their is a small black plastic box that the leads go into then out of into the compressor, ginko do you know what im talking about, if you do then i can tell pires something to try but i thought i'd ask u 1st as i'm not 100% sure.
    Pires ignore my comment to ginko unles i instruct u otherwise as it's not safe 4 the general DIYer to mess with unless i give the go ahead ok.
  • Refrigerators Master
  • 19,396 Answers
It should be a compressor fault, let me check
  • Ginko
    Ginko Apr 25, 2008
    E1 in Avanti device is general serious fault, they just suggest to contact the service. Try first to unplug the power cable for a while to see if control board resets.
    As already suggested by Pauldonp, if the above dos not work, I would have the compressor tested, if it is not the compressor is a faulty control board
    here is home repair service number:
    800-220-5570
    Avanti parts are not easy to find here you buy parts
    800-220-5570
    On this manual you find control board diagram, print diagram and pass it to the repairman
Has anyone replaced a compressor relay on this chiller? Looks like it is not designed for replacement, but if it can be done with a generic relay I would like to know. Thanks.
The cost of one of those compressors is over $100. When you factor in tax and labor you're better off junking it. Its also possible you have a compressorless cooler called Peltier.
Jul 30, 2014 | Avanti WC1500DSS 30 Bottle Wine Chiller...
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
My Avanti wine cooler is not cooling any more.
piece of junk, can not be fixed. Join all the other ones who have bought this unit.
Aug 01, 2009 | Avanti WC3201D Wine Cooler
No power, lights or anything
This is easy. It's the power supply problem. I bet you there is no juice coming out of the same electrical plug. So fix the plug or reset the circuit breaker.
Jul 31, 2009 | Avanti WCR683DZD Stainless Steel Wine...
AVANTI WCR683DZD WINE CHILLER - E4 ERROR CODE
I have the same E4 problem. You can order the PCB from Avanti at Miami Florida or your regional Avanti service rep.
Jun 04, 2009 | Avanti WCR683DZD Stainless Steel Wine...
2 mos old. simply stopped working. no power at all to lights, motor ,etc.
check if you get power by the motor if no power change the thermostat
May 13, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Mar 02, 2009 | Avanti Refrigerators
Stopped Working
THERE IS UNFORTANETLY NO HOME FIX FOR YOUR PROBLEM AS THERE COULD BE A FAULT ON YOUR THERMOSTAT OR COMPRESSOR.BEST YOU GET A TECH TO HAVE A LOOK.
GOODLUCK.
MOHAMED
Sep 19, 2008 | Avanti WCR5103SS Stainless Steel Wine...
My cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
May 27, 2008 | Avanti EWC28 Wine Cooler
Refrigerators Logo
205 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
