Question about Panasonic PT-53WX54 53" Rear Projection HDTV
Cant control the red convergence with the remote the blue and green are fine
  • Panasonic Master
  • 3,459 Answers
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Your TV will commonly have one or more of the following symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio or Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 30, 2011
Just the blue on my rca projection tv is blurred. on the auto convergeance it says it cant read the sensor. on manual the cross hairs for the blue are oversized and blurred. i tryed tuning in the focus but...
Have you try adjusting your focus/screen drive controls to Tube R/G/B you have a focus/screen drive control block to adjust each Tube 3 controls ontop 3under them top ones are for Focus bottom is for screen drive.Red/Green/Blue Tubes.You might need to replace convergence IC, what is your Model number printed on back of TV?
Mar 24, 2010 | Televison & Video
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence is off - Blue and Red are fine Green will not line up
On most units, the Green is constant and the Red and Blue are adjustable. Here are 2 links on how to manually adjust the convergence. There is a menu option using the remote control. Once there, you will find step by step procedure on how to adjust the convergence. Hope this helps answer your question. All the best!
Greg
http://www.fixyourowntv.com/menumitsubishi.php
http://www.ehow.com/how_2034880_perform-convergence--tv.html
May 23, 2009 | Mitsubishi WS-65809 65" Rear Projection...
51MP392H/17 Blue convergence wont move not IC chip
You could have some opened resistors low ohms that are bad go back and ck them around convergence ics.
Nov 20, 2008 | Akai PT4298HD Rear Projection Television
Red Convergence will not line up
YES in this set there are two convergence ics called stks...on for red and one for blue...and green is controled by both.
Apr 28, 2008 | Samsung HCN653W 65" Rear Projection...
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
Tv problem
seems like your tv got convergence problem . try setting up the convergence , use remote . if it does not help you may need to change convergence ic * 2
Oct 01, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
