The whole unit switches off after about 30 minutes. I thought it could be heating up and cleaned the fan (externally), put it on 1/2 inch brackets to ensure air circulation, changed to a different electrical outlet checked the cord and plug etc. all to no avail.
    Brigadier General:
  • 8,546 Answers
If you suspect thermal issues maybe you could verify that the unit actually feels hot when it dies. If not, it's some other cause.
Is the now-clean fan working?
I'm sure the manual of this unnamed component might give some clues as well as what the proper physical clearance around the unit should be maintained.
Posted on Aug 05, 2010
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Heater runs for 2-3 minutes then quits
Either the unit is over heating and being thermally shut down or the temp shutdown switch is shutting down prematurely.
Jan 01, 2016 | Heating & Cooling
My whole house fan has been having problems. The motor gets very hot and turns off. After cooling, it can work again (though I am not keeping it on!) The whole house fan is a Sears fan. The original...
Ada, I think you have already diagnosed the problem. It's the Leviton timer. For whatever reason, it can not handle the fan motor without over heating. The best indicator, was the melted hot wire. Perhaps the switch was defective from the start. I suspect the timer was rated for a ceiling fan and not a whole house fan.
Hope this helps you and thanks for choosing FixYa.
Aug 25, 2011 | Heating & Cooling
Must heatsink have epoxy before clamping onto mount
DO NOT use anything on the heat sink but heat sink compound!!!!!!!
Jul 21, 2010 | Dell (N1240) Heatsink With Fan
I'm trying to get my heater going this season. The pilot lights fine and heater will kick in but will only run 30 seconds max before it quits and I have to restart it. I've done this at least 20 times in a...
Does this have a fan attached to it or does the heat just stay around the unit. Does this have a thermostat or is it manually turn it on and off?
Is this in the garage or house?
1) Make sure no fans are operating when you do this.
An external fan can either **** the pilot off or blow it out.
2) Make sure if it has a thermostat that the sensing bulb located on the back is not picking up external
heat source.
3) If it has an external sensing bulb, put it in a bucket
of cold wtaer. Then try to light the pilot
Sep 30, 2009 | Procom (177653) Utility Heater
Belt snapped last night think it was serpentine belt how much am i looking at to fix?
Depending on where you purchase the serpentine belt, and whether it's a budget or lifetime version, prices range from $18 to $33.
You can replace this belt yourself.
The belt goes around, and under various pulleys on your engine. There is ONE pulley that puts tension on this belt. There is a bracket, or 'arm', that this tensioner pulley is attached to. One simply takes a 1/2 inch breaker bar, and inserts it into a 1/2 inch square hole in that bracket.
You then pull the bracket over to one side with the breaker bar, (The direction will be pulling the tensioner pulley away from the serpentine belt), and slip the serpentine belt off of the pulleys.
The belt diagram of how the belt is placed around the pulleys, should be on the fan shroud support, or under the hood.
Jul 12, 2009 | 1997 Oldsmobile Cutlass Supreme
Heat pump condinser freezing.
YOU HAVE ONE OF SEVERAL PROBLEMS , FIRST AND EASIEST TO REPAIR KEEP FILTERS CLEAN REPLACE EVERY 30 DAYS , #2 LOW CHARGE WILL CAUSE ICE ,# 3 A FAULTY INTERMITTENT FAN CONTROL SWITCH ,THIS WOULD BE MY # 1 GUESS SINCE I HAVE SEEN IT MANY TIME OVER THE YEARS , #3 WOULD BE A FAULTY DEFROST CONTROL BOARD OR SENSOR , THE REASON I LEAN TOWARD THE FAN CONTROL IS YOU SAY THE ICE IS ALSO IN THE INSIDE UNIT AND THIS IS MOST COMMON WITH RESTRICTED AIR FLOW OVER COILS AND SOME TIMES THE FAN SWITCH WILL CAUSE THIS PROBLEM THE DISCHARGE TEMPERATURE IS DIRECTLY RELATED TO THE TYPE OF UNIT ,TYPE OF REFRIGERANT IN SYSTEM AIR BALANCE CFM OF FLOW MANY VARIABLES IN THIS EQUATION,CANT SAY
Dec 20, 2007 | Ruud UAMB Air Conditioner
Nutone WA6500 range hood fan motor noisy
We have the same product, 18 months in use and the very noisy motor has finally seized up. I contacted the manufacturer and was advised that I need a new motor, motor mounting bracket and fan rotor. The agent was not able to quote me a price for the parts but stated that even though my 1-year warranty had expired, if I faxed them a copy of the original sales reciept they could possibly send me the parts for free under the original warranty agreement. I've done as they asked but haven't received a reply as yet. After reading about all the problems with this product I'm tempted to dump the whole unit and try to find another manufacturer that has a reliable and QUIET range hood.
Dec 16, 2007 | Broan-NuTone Intermediate Whispaire ...
18 people viewed this question
 Grubhead
Grubhead
