Question about Makita 14.4V Cordless Impact Driver
My Makita 14.4v battery charger says "defective battery" and won't charge. The pack is only about 8 months old and has very little use. When taken apart and tested, all the batteries show from .66v to .88v. I noticed what looks like 2 resistors and probably the heat sensor inside the pack. What's wrong and why won't they charge?
  • 1gpg2 Aug 03, 2010
    These are NiMh batteries (3000 mAh) (15 of 'em). I wondered if the resistors or heat sensor could be defective
    not really. I wanted to know more about the internal workings of the battery pack. Cost me $12 for basic nicad info I could have found elsewhere on the internet.
  • 10,865 Answers
Hello. These makita batteries have gotten low marks for durability. The batteries are shot and will not take a charge. You can go on ebay or amazon.com and buy replacement batteries if you wish to. J.
Posted on Aug 03, 2010
    They are marked "Panasonic". I wonder what would happen if I by-passed the heat sensor and resistors?
  • 553 Answers
It's not uncommon for unused NiCd batteries to develop a memory when they aren't used much. If the batteries are salvagable you can use the following method to restore them.
1) Drain the batteries completely.
2) Freeze them completely, 24 hours is good.
3) Thaw them and let them dry from condensation completely, 24 hours.
4) Give each battery a thorough charge, at least 8 hours.
After this your batteries should work fine or they will need to be replaced. When storing your batteries it's best to take them out and use them at least every few weeks and then give them a good charge before storing them again.
    These are NiMh batteries. I wondered if the resistors or heat sensor are defective
Can all 18volt 5amp makita batteries be charged on either a 240volt or a 110volt charger. Since I charged mine on a 110volt charger the green/ red lights on the charger start flashing bear in mind the...
The charger input voltage should make no difference on the output voltage / current, if they are designed to run on that input particular voltage. A 240 volt charger will not work on 110 volt and vice versa. If in doubt check the output voltage of the charger with a voltmeter. Make sure you are getting around 20 volts dc.
Mar 09, 2018 | Makita Drills
Makita DC1804T charger
No, batteries age even if not being used.
Mar 28, 2014 | Makita Univ Volt Charger
Dewalt lithium battery won't charge
Your problem states you have a Makita tool and your question is about a Dewalt lithium battery. In either case if the battery won't take a charge or if the charger is showing the battery is defective the only fix is to replace the battery. Some causes for defective batteries or batteries that won't take a charge are bad cells in the battery, bad or shorted IC board in hte battery, broken or burnt connections between the many cells or between the cells and IC board or even bad or old cells that will no longer charge up. The time and effort needed to find out what the problem is then finding another battery to scavenge parts from (individual battery parts are not available) is never worth the cost of just buying another battery and going back to work with the tool(s).
Jun 27, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
I have had my makita combo drill driver set for a week over a year. The bl1815 battery won't charge .. I haven't used it for a few months.. (2).. but the other battery is fine? What do I do? Home...
Mail it to a Makita Service center. They will replace a battery that has under 150 charges, regardless of warranty. They have a design defect in the battery which causes these spurious failures. Hopefully one day they will fix it.
Aug 30, 2011 | Makita 18V LXT Lithium - Ion Cordless...
One question please, I have makita cordlless
according to the schematic I saw yes you can and I think that you will be pleased with its performance, their operator manual even lists the weight of tool with this battery. Makita has a 1 year limited warranty on the Li-Ion battery that you might want to consider if you have the receipt.
May 11, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Can my makita bl1830 battery be repaired if it does not hold charge anymore
This battery has a known design defect that causes premature failure. The battery is still probably good, but the safety circuit n the battery spuriously locks it, due to a bug. Once locked, it won't charge in the Makita charger (flashing red and green lights). Makita knows about this problem but so far is not actively recalling the batteries. Makita will replace the pack if the charge count is under 150 (some people say 300?) regardless of warranty status, but you have to take or mail it to a Makita Service Center -- the dealers won't handle this unless it's in warranty.
http://www.makita.com/en-us/Modules/Service/ServiceCenters.aspx
If Makita won't fix it, you can try to repair it. If the red and green lights are flashing, the battery is probably locked and cannot be repaired in a way that will let it be charged in the Makita charger (but it can be charged in off brand chargers). Buy a clone charger on eBay for $60 and try it. If it charges, just use it, no repair needed.
Be aware that lithium batteries do lose capacity permanently at a rate of about 20% per year. So, 3-6 years is about the best battery life you can expect - from date of manufacture, so if it sat in the store a while that adds. Makita derates the cells to allow for some shelf life (down from 2400 Mah to 1500 Mah rating).
If the battery is weak, and only gives brief usage, you can replace some of or all of the cells in the battery. These are expensive and worth repairing. See this video:
http://www.youtube.com/watch?v=Z5taguEdlkY
If just 1 or 2 cells are weak, you can replace them with the same Sony 18650 size 2400 Mah capacity battery, green sleeve. The Sony's are not sold retail, and are hard to find other than from another Makita pack or from some laptop packs. If more are weak, you're better off just replacing all of them with new 18650 2400 Mah (or higher) batteries with tabs. Look for Tenergy or other quality brand.
Hope that helps.
Nov 02, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
MAKITA LXT BL1830 18V LITHIUM-ION 3.0AH BATTERY
If the charge count on the batteries is under 300, Makita will replace them. Makita has a known defect in this battery that causes the battery to shut down before it is dead. So as of now they are exchanging ones with low use.
If they are truly defective and makita won't replace, you have to open them, find the dead cell or blown fuse, and replace. Search youtube makita battery for a video on repairing this battery. But once the red and green lights on the charger flash, the the battery can't be charged on a Makita charger -- it's been locked. So use a third party charger.
Apr 18, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Problem charging makita batteries 18v li-ion
Unfortunately, Makita’s li-ion battery packs have a design flaw. After having the same problem with my two batteries, I took it apart and saw the problem immediately. You see each battery pack has ten li-ion battery cells and a circuit board with a memory chip witch holds the charging history of the battery pack. But that memory chip constantly draws power from 2 of the 10 batteries. The current it draws is very small but if you consider it over 8 month or more, the power drain becomes very significant. You end up with a battery pack with 8 still fully charged battery cells and 2 drained battery cells. When you put this battery pack in the charger, it detects weak battery cells, assumes they are defective and refuses to charge. To avoid this problem you should charge your battery pack often, even if you haven't used it, every two months should be ok.
I suspect that Makita doesn’t make these battery packs, they make power tools, good ones too. Buy Makita should definitely have a few words with their supplier before they become a liability!
Aug 16, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Battery charger just flashes to say the battery has to cool down but will not start charging.tried another charger same thing happens but does not show that the batteries are faulty!
Unfortunately, Makita’s li-ion battery packs have a design flaw. After having the same problem with my two batteries, I took it apart and saw the problem immediately. You see each battery pack has ten li-ion battery cells and a circuit board with a memory chip witch holds the charging history of the battery pack. But that memory chip constantly draws power from 2 of the 10 batteries. The current it draws is very small but if you consider it over 6 month or more, the power drain becomes very significant. You end up with a battery pack with 8 still fully charged battery cells and 2 drained battery cells. When you put this battery pack in the charger, it detects weak battery cells, assumes they are defective and refuses to charge. To avoid this problem you should charge your battery pack often, even if you haven't used it, every two months should be ok.
I suspect that Makita doesn’t make these battery packs, they make power tools, good ones too. But Makita should definitely have a few words with their supplier before they become a liability!
Jul 03, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 14.4V Cordless Impact Driver Logo
317 people viewed this question
Top Makita Drills Experts
John Trevino
epangan29
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
