Question about Cameras
I GOT SAND IN THE LENS OF MY CANON SD1000 DIGITAL CAMERA HOW DO I FIX IT?
  • 975 Answers
First you need to buy COMPRESS AIR ,then take out lens and spray where sand is, since theres no much information about where sand located still this will be my solution for it , hope this helps
Posted on Apr 25, 2008
I have a Canon PowerShot SD1000. When I try to turn the camera on it says " Lens error, restart camera". Can I fix this on my own or does it need to be taken to a shop?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 13, 2011 | Canon PowerShot SD1000 Digital Camera
'"The lens of my cannon
This is basically the infamous Canon "E18" error, which has been around for quite a while.
I would type out my own suggestions but since it's such a common error I'll just direct you to a nice long list of solutions already compiled elsewhere: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 01, 2011 | Canon PowerShot SD1000 Digital Camera
My camera has on the screen, "lens error, restart
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 09, 2010 | Canon PowerShot SD1000 Digital Camera
Lens Error
May 28, 2010 | Canon PowerShot SD1000 Digital Camera
Lens Error. Restart Camera. Camera gives this error message and then shuts off
how i would like a $ for everttime i have responded to this problem.There is dirt or sand possibly in the lens mechnism.
try blowing it out with canned air and then slapping it lens doewn in the palm of your hand a few times turn on and see if that has got it going again ( this is not a joke it is straight from the Canoin Tech) i did it to my own and it took abouyt 15 blows and slaps to get it wiorking again canon said it would cost $120 to fix it i found a Canon tech online and he told me how its done.. give it a go
Jun 23, 2009 | Canon PowerShot SD1000 Digital Camera
Lens error please help!!!
If the sand is in the zoom gears or auto focus gears then the camera would need to be disassembled to remove. Nice thing about this camera is that no soldering is required to take apart. A few small screwdrivers, and some tweezers would be all that is required. Canned air and a needle might also be helpful for removing the sand. If the camera just buzzes then I would say that the sand is in the auto focus gears (the stepper motor will buzz). If the auto focus lens is not fully retracted then the camera lens will not go back in (to prevent the auto focus lens from bumping against the shutter assembly)
May 11, 2009 | Canon PowerShot SD1000 Digital Camera
Lens won't close
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Apr 17, 2009 | Canon PowerShot SD1000 Digital Camera
I have the sd1000 power shot canon. i was taking a picture the camera took the picture as normal but when trying taking another shot i got an lens error restart camera.
One thing, you mentioned that the lens error occurred after you wer able to take a good picture. This really sounds like your battery ran down during shooting, and did not have sufficient power to properly shutdown the camera. Focus on your battery as the potential cause first. Note that if the battery is older than a couple years, it may be time for a new one. Rechargeable are not meant to last indefinitely.
Jan 23, 2009 | Canon PowerShot SD1000 Digital Camera
Cannot use the camera at all
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
Lens error on SD1000 Canon but opened lens and made it worse!
Lens error means that either it was dropped on the lens or the lens just failed. You could be looking at a $90-$120 repair
Dec 31, 2008 | Canon PowerShot SD1000 Digital Camera
Cameras Logo
85 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
