Question about Singer 7462 Mechanical Sewing Machine
SINGER 9836 tension mechanism doesnt work. stitches sew wrong.
I think the problem may be on the tension mechanism, i cant adjust any tension, is the same if 0 than 3 or 7, the stitches look tigth, very small and wrong.
I looked at the tension mechanism, and theres a little wire with a lace shape where the thread goes that is open, the lace is open for one side, and the wire is not stick to anything..
HOPE ANYBODY CAN HELP!!
  • pampamy May 29, 2008
    thank you for this helpful solution!
  • Singer Master
  • 1,388 Answers
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
SINGER 9836 tension mechanism doesnt work. stitche - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on May 28, 2008
TENSION ADJUSTMENT ON SINGER 9836C
try adjusting the top thread tension to one number higher at a time until the stitches start looking right
also check with singer customer service for a instruction manual
Feb 23, 2012 | Singer 5050 Mechanical Sewing Machine
My top stitch is okay, however the stitiching on the bottom is wiggly, more like a zigzag stitch then a striaght stitch. Why?
try changing the needle--flat side to the back of machine
try adjusting the tension one number up--if it doesn't help put the tension back where it is
check to make sure the bobbin is in correctly
also check to make sure the bobbin is wound correctly
it's also possible that the machine is out of time which means a sewing machine repair shop would have to refix the timing of the machine, because they have the tools for the job
Jan 31, 2012 | Singer 7426 Mechanical Sewing Machine
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
Thread tension
I have had this problem when the bobbin was wound wrong and also when the machine was improperly threaded. Check your manual to make sure you hit all the threading points, but I think the most common one i've missed that caused this was the metal loop you thread immediately before threading the needle.
Aug 16, 2008 | Singer 2517 Mechanical Sewing Machine
Stitching a mess
Either the thread is not in the tension assembly, the tension is not adjusted high enough or the thread is not in the take up assembly.
It's possible you have the wrong bobbin in the machine.
sewman7
May 20, 2008 | Singer 6038 Mechanical Sewing Machine
Tension issues
I'm working on 2 different singers. One, Singer 3343C has upper and lower tension problems that turning the dial just doesn't help. How do I adjust the tension on this drop-in bobbin carrier? My other machine is Singer Model 15 (AL311850), I'm having upper tension problems and the machine is sewing loudly-it's never done that before. Help!
Oct 01, 2007 | Singer 3343 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
479 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
