Question about GPS
My garmin nuvi 260 will not take a charge - GPS
  • 1,557 Answers
Garmin navs are famous for there chargers burning out. first check the fuse at the end of the 12v car charger by unscrewing the tip of.if its blown replace it. if its not blown then the charger has burned out there are after market chargers but only garmin chargers will work!! as garmin use a sensor to detect the correct type of charger is connected so be sure to buy a genuine garmin 12v charger
best of luck
please take the time to rate this repair.thanks
Posted on Aug 03, 2010
Garmin nuvi 260 battery does not hold a charge
If a wall powered charger is used it could be bad or the connection from it to the unit damaged---happens if the charger is connected/disconnected a lot----same thing can happen if using the lighter plug adapter for charging.
Nov 06, 2012 | Garmin nuvi GPS
Garmin gps doesn't work when charging with cigarette charger. Instead of the GPS to Navigate it rather shows like there's a data transfer.
The proper vehicle power cables for the Garmin nuvi 260 are part numbers 010-10723-06 or 010-11478-03.
The use of improper cables will cause the nuvi to go into mass storage.
You may also want to contact Garmin Support for assistance.
http://www.garmin.com/us/support/contact
Sep 23, 2011 | Garmin nuvi 260 Car GPS Receiver
My Garmin Nuvi 260 is not on the recall list but will not charge or stay on - it does start up but after allegedly loading the maps, it turns off
The recall is for an overheating battery issue which can potentially cause a fire. Your problem is totally unrelated and is most likely simply due to the rechargeable battery being exhausted.
Replacing the battery is supposed to be a Garmin service centre job, but they charge silly money for it. Do it yourself instead, click here for a free instructional video.
Good luck, please take a moment to rate my reply.
Sep 22, 2010 | Garmin nuvi 260 Car GPS Receiver
The USB port on the NUVI 260 is loose and will not charge
You will not be able to refasten it yourself. This is a surface mount part and you need a very small tip soldering iron to fix it, plus you ned to know how to modify it so it wont break again. Please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Oct 19, 2009 | Garmin GPS
Garmin nuvi 260
What you would do is, under where the model code sticker is under is the reset button. remove the sticker and hold down the reset button for 10 seconds at the same time hold the power button towards the left.
May 14, 2009 | Garmin nuvi 260W GPS Receiver
Garmin Nuvi 260 maps loading
http://www.garmin.com/garmin/cms/site/us/support/
Hope this helps
Apr 05, 2009 | Garmin nuvi 260W GPS Receiver
I have got a nuvi 260 and it wont come on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
New Garmin 260 W won't do anything when plugged in.
Your PC may not be able to charge it. If it does it's only a trickle charge. May take a day or two
The Garmin cigarette lighter charger take 4 hours.
Dec 26, 2008 | Garmin nuvi 200W GPS Receiver
How long to the initial charge for the Garmin nuvi 260
how long to charge the battery for garmin nurvi 260 initially using the ac adapter?
GPS Logo
291 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
