Question about GE Microwave Ovens
My GE microwave regularly needs resetting. When the problem appears, the microwave no longer responds to the touch pad and starts running until I open the door. To get it working again, I just unplug and plug in again and it works fine. Usually, the problem starts when I shut the door. That probably messes up some circuit. Perhaps a circuit board needs to be replaced, but I await advice from someone experienced with these kinds of things. Thanks.
  • 6,831 Answers
Hello
OK, this is most likely an circuit board error. I would advise you to first have a look at these new units. The thing is, i suspect this is a firmware related error, but if you are considering to buy a new circuit board, you need to keep in mind that the labor and the new board will probably cost you the same as a new oven.
So, i would suggest that you take the unit to the nearest repair shop and let them determine if this is a circuit/firmware error. It might just be an simple contact error.
If this is a circuit error, have a look HERE before you buy a new circuit board.
Please do not hesitate to let me know if you have any further questions.
Kind regards
Andrea
Posted on Aug 03, 2010
GE SPACEMAKER MICROWAVE OVEN MODEL J VM64 003 LIGHT SWITCH BROKE HOW DO I REPLACE IT?
Unfortunately it appears none of these parts are avail anymore. The physical buttons, key panel assy, touch pad support are no longer available. The smart board (WB27X5239) seems to floating around, but this does not appear to contain either of the 2 buttons or switches as part of it's assembly. Pleazer Appliance..
Jan 11, 2015 | GE Microwave Ovens
Why is my GE mircowave starting by its self ?You do not even have to in the same room and it just starts running.
The touch pad could be giong bad and closing the contact by itself. A new touch pad should fix this.
Aug 18, 2014 | GE Hotpoint RVM1535 Microwave Oven
GE HVM1540LNCS 950 Watts Microwave Oven touch pad won't respond
We regularly repair microwave control panel assemblies, usually for $39.95, but if your keypad is bad, it will run more.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
http://www.microwavedisplay.com
Jul 30, 2010 | GE HVM1540LNCS 950 Watts Microwave Oven
GE model JVM5503 (1980): light and exhaust fan work, but touch pad does not respond to pressing buttons and therefore no functions can be initiated.
That would be a problem with your "touch control" but it is no longer available.
The oven will have to be replaced.
Sounds like it had a good run.
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I get it out of lock mode
If the model number you have listed is correct, you turn the Child Lock feature on/off by pressing and holding the "Clear/Off" button for three seconds. The instructions are on page 28 of the Owner/Operator Manual.
If your model number is different from the one you have this question posted under, please post back with your correct information so that I may be able to provide you with better assistance.
I hope this helps you.
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
When pluged in the exhaust fan runs all the time and the key pad does not respond to any touch controls. this happened after an electrical stom. no other appliances have been affected.
It sounds like you need a new keypad. Unplug the microwave and then plug it in again. if you get an F3 error message it will confirm the keypad is bad.
Oct 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave works intermittent, when not working display reads F-3 and key pad does not respond
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Sep 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave beeps
HI. the touch pad is defective at this point. you will need to replace this damaged touch pad board asap. this will fix your issue.
Aug 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Keypad on ge spacemaker microwave oven not working
Needs a new touch pad if it doesnt respond, you can check the connection between the touch pad and the pcb, but it sounds like there is an O/C on the pad.
May 18, 2009 | GE Microwave Ovens
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
