Question about Timex 27191 Wristwatch
Hello. The crown and stem fell out of my timex indiglo wr30m and was lost. How can I get that fixed, and is it worth repairing for the cost? Thanks
  • 93 Answers
SOURCE: My crown fell off the stem of my Gucci watch. How
If you still have the crown you may be able to put it back on yourself. However for a secure repair you would need a watchmaker to repair this.
To try yourself get some RED locktite (available at any Ace hardware store or automotive store) Put a small amount on the threads of the crown. Then screw the crown onto the stem as much as possible.
Let it sit for about 10 minutes so the locktite can cure. Then you can try using it to set the time or whatever.
If this does not work you will need a watchmaker to repair this.
Prices to fix this would vary.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Posted on Nov 03, 2009
  • 2501 Answers
SOURCE: hourly chime
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Posted on Feb 25, 2010
SOURCE: Can't get the back plate of a Timex Indiglo WR30M watch back on
To open watch case, hold back of watch up with arrow pointer on the back plate pointing to the right. There is a pry point on the upper edge where you will see a small arrow pointing. Use a small flat end screw driver to pry the watch case open. Be sure to replace the back the same way with the arrow pointing away from the setting knob.
Take a 1-1/4 inch paddle bit and drill a hole in a 1-3/4 inch wide piece of wood about 1/8 inch deep. Then take another piece of wood about 2 inches long by 3/4 inch thick by 1 inch wide to lay across the back of the case plate. Place the crystal of the watch in the drilled hole. Used a vise or clamp with the watch between the two blocks of wood to press the back on. Be careful not to over press. Works great
Posted on Jun 05, 2010
mcdevito75
  • 1970 Answers
SOURCE: how do you remove stem from timex indiglo with
mcdevito75 Here, I've myself ruined a number of watches with Quartz movements trying to remove the stem, see your local jeweler and have them do it. Look for the small watch repair shops to save some money.
Posted on Jun 16, 2010
watchmacher
  • 302 Answers
SOURCE: how to replace stem and crown in timex indiglo
If you have the stem and crown take it to a watchmaker. If not it is cheaper to buy a new watch
Posted on Mar 16, 2011
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
Crystal fell out and lost of indiglo quartz timex. where can i get a replacement crystal
Hello Margaret Papa,
The nearest TIMEX Service Center...
Don't want to presume you are in the USA... but if you are Timex Service...
https://www.timex.com/contact-us
Carnac the Magnificent
Jan 06, 2017 | Crystal Watches
How to replace stem and crown in timex indiglo watch?
Mar 16, 2011 | Timex Indiglo Analog Watch
How to remove stem on timex indiglo WR 30M ?
Insane as it seems, apparently the Indiglo wr30m watch stem does NOT have either a set screw or a release button. No vice needed though, just good fingernails. Pull it out one click to the 'set time' position and pull it out some more and it comes out.
Mar 06, 2011 | Timex 27191 Wristwatch
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
Hourly chime
manual download"
Feb 25, 2010 | Timex Indiglo Analog Watch
Timex Expedition Compass watch stops randomly.
Some watches have crowns that screw in after being pushed home, is this the case with yours? If it is then that could cause the problem described. (Turn crown clockwise).
I looked at one or two of the Expedition instructions (the are a lot) but couldn't find any mention of a screw in crown.
I suggest that you go to Timex.com and at the bottom of the page is "manuals/downloads" select this and the "product manuals". Put your watch type in the search box to obtain your manual.
If you are still not able to solve the problem, the I suggest you take it back to a Timex dealer to sort it out.
Jan 28, 2010 | Watches
Timex 27191 Wristwatch Logo
816 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
