Question about Sony Ericsson K320i Cellular Phone
How to solve no sim problem - Sony Ericsson K320i Cellular Phone
My nokia n8 restart after insert sim card,can you give me a solution for that problem please.
Restart:::
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
FOR INSERT SIM:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Jan 21, 2013 | Nokia N8 Cell Phone
When i make a call with my nokia 7020 i can hear the contact but they can't hear me
First you should locate the problem; phone or sim.
CHECKING FOR SIM
Put another sim in your phone.
Does the problem persitst?
Yes (The problem is not from the sim)
No (The problem is from the sim - to solve it, get another sim of your same network, call your mobile service operators, and inform them. They should help further).
Or
Put your sim in another phone.
Does the problem persist?
No (the problem is from YOUR phone).
Yes (It confirms the sim problem, and solve it as such.)
TREATING THE PHONE
The problem with the phone is that the microphone's bad. This should be replaced, and can be done at the local phone repairs.
Pending that repair, you can conveniently make your calls using a hands free device.
I hope that solved your problem?
Do have a great day.
May 27, 2011 | Nokia 7020 Cell Phone
Dual sim china mobile show on screen invalid sim
I HAVE A CHINA SET SIGMATEL S90 DUAL SIM ONLY SIM 1 IS WORKING FOR SIM 2 SHOWS AS INVALID SIM FROM FEW DAYS PLEASE SOLVE THIS PROBLEM
BABU
9035040544
May 27, 2010 | Sharp Cell Phones
I woke up andMy phone says to insert sim card but it is in
  1. Power off phone
  2. Remove battery and SIM
  3. Reinstall battery and SIM
  4. Power on phone.
Problem solved? If no, then,
  1. Power off phone
  3. Put your SIM into another phone.
  4. If the SIM works with the other phone, then:
  • Clean the contacts of your phone's SIM receptacle.
  • Blow near the SIM area of your phone.
  • Reinstall SIM and Problem solved! If stills without recognizing your SIM is time to take your phone to service.
  1. If your SIM doesn't works with the other phone, then replace your SIM.
Nov 23, 2009 | Computers & Internet
Sir my zong sim is lock
sir i have zong sim my sim is block how to unlock please tell me how to unlock
Jul 18, 2009 | Lands Phones
Nokia 1100 sim not valid
nokia 1208 sim not valid plz solve my problem
Apr 09, 2009 | Nokia 1100
My sagem has been showing me sim lock how can i solve it
I have a sim problem., my phone is showing me sim barring, that i can't use it in making call, i need my phone to be deactivate the
barring. 07064478757.
THANKS
Apr 03, 2009 | Sagem my201X Cellular Phone
Insert sim
just clean the connectors, thats it
Feb 09, 2009 | Nokia 6070 Cellular Phone
Sim card rejected
this happens when ur sim cant establish registration with the preffered networkk . this is not a phone problem . ur sim card may not hve been used for long time (recharging account) . please contact the nearest office of ur network provider
Nov 06, 2008 | Nokia N73 Cellular Phone
Sony Ericsson K320i Cellular Phone Logo
27 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
