Question about GE Spacemaker JVM1640SJ Microwave Oven
Turntable makes a clicking noise while turning
4 Suggested Answers
  • 4 Answers
SOURCE: Convection microwave turntable does not turn.
Try removing the turntable plate, and then lift up on the roller assembly that the plate sits on. These roller assemblies are usually made of plastic, and often times the center "axle" (the part that goes down into the hole in the bottom of the microwave) breaks or cracks. If it looks like this piece is cracked or broken, just take it down to an appliance repair store (or just write down the model # of your microwave and bring it with you). Replace the roller assembly, and you're good to go.
You can also find these roller assemblies online pretty easily as well, and they're usually under $10 USD.
Good Luck.
Posted on Aug 25, 2009
  • 18 Answers
SOURCE: GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Posted on Nov 21, 2009
  • 2811 Answers
SOURCE: Frigidaire PLMB209DCC
the noise is the turntalbe trying to catch on the motor below soundslike it worn out
Posted on Jan 22, 2010
Jvm1640bb 006
Yes it can be replaced. But first make sure the noise isn't coming from the guide roller assembly or coupler which is the plastic part in the bottom of the microwave that turns the turntable. .
Jul 19, 2014 | GE SpaceMaker Microwave Ovens
My microwave makes a grinding noise when running and the turntable doesn't work.
Possible there is friction within the drive , the shaft or the motor. You can remove and RESET the drive. Remove the motor , MANUALLY check the motion of the mechanism which will confirm the case. You c an reset using a bit of lubrication.
Jan 10, 2013 | Microwave Ovens
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag Microwave 1150 Help
Check first the motor coupling under the turntable, if that is not the problem , then test and eventually replace the turntable motor.
Click here and select model to get parts and diagrams.
Apr 05, 2009 | Maytag MMV4205 Microwave Oven
Turntable makes grinding noise and barely turns
Unplug unit and take bottom off of it with the screws that go around the outer edge. The turnatanble motor has 2 screws and is removabe from the bottom underneath.
Sep 24, 2017 | GE JES1851 Microwave Oven
Turntable makes a popping noise
The problem with turntable motor or coupler which sits on turntable motor shaft.
Nov 30, 2008 | Whirlpool MH7135XE Microwave Oven
Microwave turntable won't turn
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
  • Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
  • Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
  • Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
  • Be certain you are pressing a cook function rather than a timer function.
  • If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
Sep 21, 2008 | GE JVM1850 1000 Watts Microwave Oven
Turntables doesn't work and makes horrible noise
Replace turntable motor. Not really that hard to replace or expensive. Remove all screws holding bottom panel (usually three across each side and one to three in front) to gain access to the turntable motor. The panel will hinge in the back.
Jun 01, 2008 | Frigidaire PLMV168 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
232 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
