Question about Sega Genesis Console
I recently bought a sega genesis off of ebay and also had to get an a/v cord. I plugged everything in and the only thing that happens is there is a flash across the screen when I turn it on. I tried this on 2 different tv's in my house and still the same thing. I checked to see that the a/v cords were still plugged in but nothing happens. The console powers on and everything any advice???????
  • 1,557 Answers
Wow i have not seen one of these since i was in teach school. in some cases its due to carbon build up on the copper pins at the base of the cartridges (games) using a cloth with window cleaning solution clean along the copper strip and re insert game. if this does not work then the internal strip inside the machine will need to be cleaned.
good luck
Posted on Aug 03, 2010
    Problem Solver:
  • 5 Answers
It means you first of all need to clean the games. Get out a Q-Tip, rub it inside the games along the copper strip. Dirt will come out. If this doesn't work, do that same method with a cleaner like Windex. Then rub a dry Q-Tip around to soak up the liquid. Let it dry for 20 minutes or so.
Still not working? Get out a pencil with a clean, never used eraser on the tip (The pink/red eraser on the tip) and rub it inside the game. Then get all the shavings out with a Q-Tip. That method breaks the electro-static cling from when the games are being read by the system.
If it's still not working, it's either the system or the AC cord. Lots of people have the AC cord problem, and it has to be turned juuust right. Same with the video cord (That plugs into the VCR or TV.) I just went out and got a new one of both, cleaned the games, and it was working great again.
Posted on Aug 10, 2010
Missing the part that plugs from console to television where do i find?
  • Hi, I can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 29, 2011 | Sega Genesis Console
I recently aquired a model 2 sega genesis. i have an av cable and a power cord with the same plug. it turns on but it wont play any video. can anyone help?
Without specifics its hard to say what the precise problem is so ill give you a list
ok the power adapter for mine which i've had since it was released has an input of 120v as 50hz 15w and an output of 10v DC 0.85 A if its not outputting that that may be the cause so get a new cord
Make Sure you plugged in everything correctly and power spike is on if using one (better safe then sorry)
Its HIGHLY possible that who ever sold it to use ripped you off and you have a broken Genesis
Feb 20, 2011 | Sega Genesis Console
Wont come on
Man I haven't seen an actual Sega Genesis console in years. Anyways...
1) Make sure that everything is plugged into your system properly. 2) Check you make sure your TV is on the right channel 3) Check to make sure the fan is at least powering up when you turn on the Genesis. If it is then the Genesis is working. 4) Plug something else into the TV to make sure it works.
Remember, HDTVs and LCDs and this whole Al Gore's Gone Green thing wasn't around when they made the Sega Genesis, so conventional means to playing a Sega aren't your best option. Don't plug it into the wall either, make sure you are plugging it into a surge protector.
Hope this helps.
Jan 01, 2011 | Sega Genesis Console
I plugged in my genesis today and everything if fuzzy too how can i fix it
try jiggiling the yellw cords. if this does not work you could buy a new cord pretty cheap off ebay.
Nov 26, 2010 | Sega Genesis Console
How do i install a sega genesis 16 bit to my tv and what kind of cords do i need
Sega genesis has a proprietary plug which goes to a standard RCA Style cable. They go for about $9 on eBay.
Or you can get one from Amazon here.
Apr 29, 2010 | Video Game Consoles & Games
No video from my Sega genesis?
its gone mate...the thing is gone, happens you need to get anotherone
Mar 20, 2010 | Nintendo Super NES Console
How do i set up my sega genesis
There should be regular av cables and wall adapter for it. Mine came with the wrong cords and that might of happened to you. So if you don't know the av cables go in the back of the tv and plug's in the back of the sega. and the wall adapter goes in the wall. If you don't have the cords than get them off line. Type in:
http://www.amazon.com/s/?ie=UTF8&keywords=sega+genesis+cords&tag=googhydr-20&index=aps&hvadid=2858659671&ref=pd_sl_8zrz6m8bxu_b
cut and paste it online and you can get them.
Jul 18, 2009 | Sega Genesis 2 Console
Sega Genesis not showing a picture
As I had just a similar problem with my MegaDrive/Genesis maybe this helps: Try an older TV set. I am not joking. It might very well be the case that newer TV sets/high-end TV systems can't handle the signals of the older video game systems. I have a 100 hz TV set and whereas there are no problems with a SNES, with the MegaDrive I just had a black and white screen with bars running through it. On a 60 Hz TV set this problem does not occur. Keep in mind that there were no 100 hz/HDTV sets around when these video game systems were in general use.
Jun 18, 2008 | Sega Genesis Console
How to clean the contacts inside the Genesis.
Honestly, especially with those older consoles, I wouldnt trust any type of liquid with it.
Mar 10, 2008 | Sega Genesis Console
Sega Genesis Console Logo
348 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
