I have a samsung big screen and it has a yellowish-brown tint. i looked online before and it said there was a little bottle of some kind of liquid or something that you put in your color tubes i believe. is there anything like that? or how can i fix my color problem? please help me. thank you...
    Problem Solver:
  • 19 Answers
Does it look cloudy? go here...That will give you the best description of this problem! :) Good luck
*please Rate*
Posted on Aug 05, 2010
Phillips rear projection tv model number 50pp920217f the screen had kind of a yellowish tint
I would bet that it is your optical block. Often when these go out, you get a yellow or green tint to everything.
Jul 10, 2013 | Televison & Video
The screen has a yellowish color tinting the entire surface. No blurring, just poor color. I'm thinking the 3 tubes(red, green, blue) may be toast?
Hi,thats could from your convergence color ic call stk
;you may need to replaced before looking for the tube thats may just an ajustement on tube screen control beware for high voltage
that is depend how old is the tv and the number of hour it play a day....
hope that will help
May 04, 2010 | Samsung HCL4715W 47" Rear Projection...
Can't fix the color - really blue or really yellow.
Probably Blue CRT shot. Put tint back to center and turn color level to 0. Should look good black and white pic. If blue CRT shot, will look yellowish; usually more yellow around perimeter.
Apr 14, 2010 | Samsung HCM4215W 42" Rear Projection...
Sony trinitron kv36fs13 the picture is fine but there is yellowish green tint on full screen
Yellowish tint in picture shows that TV needs increase in blue gain because picture tube is bit weak in result.
If you are handy with electronics repair then let me know to guide you further.
Jul 12, 2009 | Sony FD Trinitron KD-34XS955 34" TV
Panasonic 56" projection color problems
there are so many technologies for the projection tv's ever one has their own caracteristic faults with out you mention the technoligy used on your tv will be deficult to help you but assuming is a lcd projection you must have a problem with the optical block the repair will be expesive if you do not have a manufactuer warranty for it
Jan 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Samsung HCN2446W -- Yellow/Greenish tint all over screen
That model should be HCN4226W, right? Because the other don't come-up. Sounds like the mirror may have moved. It's mounted on the upper part of the back of the T.V. Should be flat against the back. Check that. Then see if all 3 tubes are lighting up. Also possable the fluid leaked out.....but not likely. These sets are fairly robust. Do you remember jarring it in the drive home?? Did you have it laying down when you moved it?
Dec 14, 2008 | Philips Magnavox 51MP392H Rear Projection...
How do you access the heater core on a 1998 buick reviera?
look closely if it is coolant. normally it woiuld have odor, hot/warm, or yellowish or brown in color.
if it is clear and cold, it could just be the water condensate from your a/c unit passing to the heater housing.
if it is really coolant, then it is a big job to change it and it is not a common problem.
tnx 4 using fixya,
Drcool
Nov 16, 2008 | 1998 Buick Riviera
White colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Jul 20, 2008 | Akai PT5598HD 55" Rear Projection...
Yellowish color
turn off the color and see if you have a good grey picture if not your grey scale is off and requires adjustment
Aug 26, 2007 | Hitachi 43F300 43" Rear Projection...
Dark (brown-yellow) area on the screen
Dalnel97,
Did you ever find a solution to your yellowish brown blob? I have the same problem with mine here at work.
Jun 12, 2007 | Panasonic PT L720U Multimedia Projector
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
