Question about Dell Studio 15 Laptop
Neel-Pc - Dell Studio 15 Laptop
    President:
  • 2,571 Answers
I am trying to find a way to use my calculator and its financial functions but i have no idea how. i need the present value of $1 and present value of annuity of $1
Neely Neel Neel Neelerson,
--> APPS
--> TVM
Viola. The initials TVM stand for Time-Value-Money; it's a widely used tool throughout financial mathematics. If you are looking to deal with annuities, bonds, present value equations, future value equations, or even certain stocks then you will want to use the TVM app within your TI-84.
When you go into that menu screen you will see about 10 input lines; and despite how you're being taught you'd be best off using only five (from a mathematical & conceptual standpoint). The backbone of the TVM is the time-zero equation of value. So, all you want to be touching is the N, I/Y, PV, PMT, and FV keys.
Background on TVM:
N = Number of intervals
I/Y = Effective Interest Rate Per Interval (5% is .05 but the computer wants it entered as 5.0)
PV = The Present Value
PMT = Recurring Payment (either deposit or withdrawal)
FV = Future Value
There are like 3 other inputs that I encourage you to ignore (in exchange for learning exactly what's going on within this application).
NOTE: You MUST make your effective interest term match your number of intervals. For example, an annuity with monthly payments for 5 years with a monthly effective interest rate of 2% would need an N value of 60 (which is 12 months per year times 5 years for a total of 60 months).
There's more that could be said, but I think this should help you find the PV of an annuity.
Go Bulls,
The Math Cheetah
411@themathcheetah.com
Mar 13, 2011 | Texas Instruments TI-84 Plus Calculator
I neel to put tension on the alternator belt on a
the alternator is the adjuster,loosen all the bolts,jimmy the alt out away from the block, then tighten bolts,check not too tight after above.
Jun 06, 2010 | 1999 Nissan Sentra
I have a tom tom 930.
get the latest tomtom Home 2.5 application from www.tomtom.com and use this app. to install your new map. you may need to set up a registeration when you visit tomtom, but the map should go on to the device as long as you have room. put everything else i.e. phonebook, music, pictures on to the card.
Jan 15, 2009 | Tomtom GO 920 GPS Receiver
Goblet of fire PSP Can't save
I had the EXACT same problem....it would go no further that that looking for memory card screen....apparently the game will not accept that big of card....install the standard 128 or 256 mb card and the game will run normally...it worked for me...Good Luck :)
Darin
Dec 23, 2008 | Sony PlayStation Portable (PSP) Console
In the Camera mode there is no image just a blank screen
I presume you have checked to see that the lens cap is off? You could also make sure you don't have the "Fade-in" function turned on. Do you see anything at all? Text? If you see text, it indicates that the LCD monitor is working and that you are in some mode that is not letting light get into the camera. Make sure you are ion the all-automatic mode. If you see nothing at all, I'll bet there is something wrong with the screen or the wires connecting to the screen. Do you get an image in the viewfinder?
Nov 08, 2008 | Sony Handycam CCD-TRV608 Camcorder
Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How to clean ice maker door on a Kenmore
is it a side by side or trio with french doors ? we will asume is a side by side under the dispencer trip there are two small slots were you insert a flat screw driver. now twist to unlock them once you remove that cover you can see more inside and how you can have more access but be care ful disconect unit if possible
Oct 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
To purchase telescope
i want to bye new telescope for my son in gujarat
anybody has address how can i bye
Mar 22, 2008 | Optics
Need help to set-up fcpga processe on asus P3V4X with asus-S370-L
Hi Neel, Are you running the board in JumperFree Mode? If so you shouldn't have to change any jumpers or dip switches. And the S370-L adapter card should NOT have to be set either, it should auto detect both processor core and voltage. If you don't know how to set the board up in JumperFree Mode let me know I'll walk you through it. If you ARE running in JF Mode then I'd contact Asus support. http://support.asus.com/ You have the right BIOS update to be able to support that proc but Asus had some issues with Intel chipset support with certain versions of the 370 adapter cards. (issues with both the S370-DL and the S370-L if I remember right) Let me know what happens, Dude
Nov 25, 2006 | ASUS (S370L) Processor Board
Dell Studio 15 Laptop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
