Question about Compaq Computers & Internet
How to identify power supply chips in mother board
    Scholar:
  • 104 Answers
Power supply chips will be usually 24 pins or 20 pins. It will be a male kind of pins with white plastic surrounded by it. The power will come from the SMPS which will fixed on the top of the CPU in the back side. The power supply to the processor is again a male pin which is of 4 pins. this will be located very near to the processor itself.
Posted on Aug 03, 2010
When building a gaming computer the power will only stay on for a second then immediately turn off have replaced the power supply mother board and processor
might be that the power supply unit is inadequate for the MB requirements
The more powerful the MB and chip the larger the power supply requirements
has the correct paste being used under the heat sink on the chip to dissipate the heat generated
Jun 14, 2018 | Power Computers & Internet
Hp Pavilion, Power supply Inactive, HHD savagable, intel Chip Savagable, i was thinking a new motherborad for the chip and the hard drive ????
If your Desktop not start it means not you mother board problem because starting you find your SMPS proper running or not. Because SMPS supply all power in CUP so you check it SMPS on or off position. if SMPS ok then you check it mother board light on or not, if on then ok or not on then you change SMPS supply.
If your display issue then you check it RAM and HDD.
Thanks.
Computer Support
Feb 20, 2014 | HP Pavilion a305w (DM181AR) PC Desktop
My msi ms - 7352 ver :1.0 won't display but wen i plug the power cable on the power supply the cpu fan and power supply fan spin but wen i turn the pc on it doesn't display
Auto power on the mother board means there was not found RAM or VGA adapter. If you herd Beep tones
follow this link to identify the error
https://forum-en.msi.com/faq/article/bios-beep-codes
if not pls check the power supply 4pin connector correctly plugged .
Also need to check the cpu and post error codes by post diagnostic card to identify the eror.
Oct 24, 2013 | Computers & Internet
My s88m g/gl motherboard is not switching on ,but the power supply is working
Power supply is other thing, means she ( Power Supply ) supply the power to *********** board. When mother get the power than she supply all the device. If, *********** board have problem, means not connect properly or burn ( any device ) than she not run. Better you check your all connect device with processor also.
Aug 12, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
No power,power supply seems ok,green light on mother board on. when pluged in the fan runs for a couple seconds and turns off.power button has no effect.
sounds like a mother board issue,
start with pulling out all ram chips and re try,,
then try pulling all cards out like old modem and also cdroms.
if ever thing but power is unpluged its a bad mother board or CPU chip
Mar 12, 2010 | E-Machines T3958 (827103050974) PC Desktop
T2984 won't power up
I've re[lace alot of bad eMacines power supplies. Nearly all of them took out the video chip on the mother baord, rendering it useless.
Mar 23, 2009 | E-Machines eMachines Refurbished EMA...
Problem getting hard drives to run
check the power supply. some time power supply not suppling the proper voltage to the accessories.
Nov 26, 2008 | Intel Motherboard
Inspiron 6400 DC input fault
please remove the power supply pin from the mother board short the pin witres colured green and black if the power supply is working then there is no problem with the power supply check ur memory card to if the pwoer supply is working iff its ok and still not working contact a chiplevel engineer to correct the mother board as there is problem with powersupply section in ur motherboard
Oct 22, 2007 | Dell (8N816) Motherboard
Computers & Internet Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
