Question about Danby DPAC8020 Air Conditioner
I have a DPAC 10030 which is pumping out cold air as expected, but there is an accumlation of water under the unit and no water in the internal or external tanks. I can hear water spashing around in the tray when I shake the unit, but that water does not seem to flow to any water resevoirs as expected. Is something blocking the flow?
  • 6,826 Answers
Yes, I would check the flow of water to the reservoirs and clean the machine of any blockages in the water tubing or routes.
I searched for dpac8020 and dpac 10030 but did not find it on the U.S.A. Danby site. Is this unit located in the U.S. or abroad?
Posted on Aug 03, 2010
Remove Water Tank
  • require you empty the unit by hand (usually less expensive units). These have either a removable water tank which must be emptied, or have an internal tank and a drain, where you have to empty the water into your own pan. Sometimes the drain is on the bottom of the unit, making it hard to find a pan that will fit under the unit to drain it.
  • discharge most of the water through the exhaust hose (usually more expensive units). This is called "Auto-evaporation" or "Self-evaporating" feature.
Most units are made so that they can be drained with a gravity hose that flows to a drain inside or outside your house. But the water must drain down. If the drain is higher than the unit, you may need a condensation pump to move the water upward. A few units do include a pump to send the water a short distance through the drain pipe.
do no forget to rate the solution as fixya if it helps you.
thanks.
Jul 02, 2008 | Danby DPAC10031 Air Conditioner
Danby dpac 10071 air conditioner is not cooling. a red light is on next to an icon with a full cup. Does anyone know how to make it cool?
That indicates that the water collection bucket is full and needs to be drained. Once the unit is turned OFF, unplugged and drained, the unit will start up and start cooling again. The drain hole is on the rear of the unit, just above floor level. You can either drain it in a shallow sided pan capable of holding 1 quart of water. Or roll it to a floor drain or outside to drain it.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Danby DPAC10061 Air Conditioner
I have a 7 year old danby portable air conditioner it seems to work good but my neighbor just purchased a new 12000 mine is 10000 he said he has to empy water frequently We have never had a drop of water...
This model is designed to heat the condensed water and send it out the exhaust duct as vapour. It prevents accumulation on less humid days. It sounds like it's served you well for seven years.
However, I do recommend one step for owners of the DPAC series. At the end of the season, drain the internal tank by opening the two taps at the bottom rear. Put a pan beneath them . The internal tank only holds one cup of water.
Jul 10, 2010 | Danby DPAC120068 Air Conditioner
Water accumlates inside refrigerator
The defrost drain is plugged up. You must access the evaporation department and open that drain. I have free repair manuals HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 19, 2010 | Refrigerators
Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Aug 03, 2009 | Danby DPAC8020 Air Conditioner
I have a Danby DPAC 8020-5 air con unit. Air con
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Jul 29, 2009 | Danby DPAC8020 Air Conditioner
Unit does not cool with the exhaust pipe connection covered
you need to get the exhaust air out if the structure or it will never work, you can use regular duct from a supply house as a temp fix
Jun 01, 2009 | Danby DPAC10031 Air Conditioner
Water Cooler Not cool
hi,
Please check the control.
May 06, 2009 | Heating & Cooling
Danby DPAC 8099 Moisture Removal problem
If the dew point of the air in your place of operation is low you will not get moisture out of the air. Generally when the unit is first used it lowers the indoor humidity and you get a lot of moisture. Once things settle out the amount of moisture will decrease.
May 17, 2008 | Danby DPAC8099 Air Conditioner
Danby DPAC8020 Air Conditioner Logo
108 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
