Question about Canon P170-DH Calculator
How do I set the time and date on a canon p170-dh
  • 9 Answers
Press the Date and Time button on the calculator. It is to the right of the Feed button and has a small calendar and clock on it. To set the date, press the button once to display the factory supplied date and hold down the Equal ( = ) button that is two buttons below Date and Time until the screen flashes. Input the correct date. Ex: August 20, 2010 would be entered on the numerical keyboard of the calculator at 08202010. When finished, hold the Equal button again. Do the same for the time.
To sum it up:
Press Date and Time button
Hold = button until blinks
Enter date or time
Hold = button again until blinking stops
Posted on Aug 20, 2010
  • 1 more comment
  • ads9296 Dec 14, 2010
    This is exactly what I am doing and the numbers just keep blinking!!!!
    Any suggestions?
  • JamesK852 Mar 14, 2011
    If you don't have the month and day properly entered it will just keep blinking until you have fixed it (Try reversing them)
  • ray_haug
    ray_haug Dec 20, 2012
    If it is still blinking then you are probably entering the Month where the day should be entered and vise versa. On my calculator, I had to hold down the "Time Set" or "M+=" Button in order to change the date and time.
Hit # key to change am/pm
Posted on Oct 05, 2011
4 Suggested Answers
SOURCE: Canon P170-DH
I played around with mine and found the keys that you change the time and date with by looking over the top of the keyboard. On my model there is a time and date key that has a little calendar and clock actually on the key. That key allows you to switch between date and calendar. After you click on that button you will either see a date or time. To change those numbers use the following keys: The equal (=) key will change date and time by holding the key down till the numbers on the display start to flash. Once they start to flash use the number keys to make your changes. The multiplication (X) key you can use to change am and pm. If you want military time use the division key. If you are changing the date there is an additional key that lets you change the format. What this means is the sequence on the display by the way you view the month, date and year. You can change it so year shows first then month and date or interchange day and month. Once I found those keys it was easy.
Posted on Mar 11, 2007
SOURCE: Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Posted on Feb 17, 2009
old marine
  • 2178 Answers
SOURCE: Setting tax rate on a canon P170-DH
To set the tax rate, slide the "GT" switch to RATE. Enter the tax rate (i.e., 4.5 for 4 1/2 %). The display should show 4.5 %. Slide the "GT" switch to OFF.
Posted on Jul 30, 2008
I have a Canon P170-DH desktop calculator with no instruction manual. I would like to know how to set the date and time on it. Thanks. annette
It's the first thing in the manual.
You can download the manual from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/office/calculators/desktop_printing/p170_dh#BrochuresAndManuals
Feb 09, 2011 | Canon P170-DH Calculator
I lost my manuel howdo I set time on my Canon P170-DH and date
Aug 03, 2010 | Canon P170-DH Calculator
Where is the time set key on canon p170-dh
Press the button to the right of the FEED button twice. The first time you press it will be for the Date, the second will bring up the time.
May 13, 2010 | Canon P170-DH Calculator
I am confused as to how to set the date/time on the Canon P170-DH calculator - the instructions are a bit "gray"
I continued doing some online research on the question and found the solution. Thanks.
Oct 23, 2009 | Canon P170-DH Calculator
Can't set the time on my Canon P170-DH adding machine
1. Press the calendar/clock button twice
2. Press and hold the Clock/Date Set (or Time Set) button for three seconds.
3. Use the numeric keys to enter the time -- four digits (i.e., 0730)
4. Press the AM/PM button to select
5. Press the Clock/Date Set (or Time Set) button
6. Press the C/CE button to return to calculation mode
Aug 27, 2009 | Canon P170-DH Calculator
Jan 10, 2009 | Canon P170-DH Calculator
Canon P170-DH
for calandar
turn on.
press clock calandar button, top row second from left.
press time set button, second row from left, 3rd button from top, (has time set printed diretly above)
enter numbers, say 03 05 2009
press time set button 3 seconds
press CE/E, red key at bottom left corner.
turn on
press clock calandar button once, date will show
press clock calandar button 2nd time, clock will show
press time set once
enter time
press am/pm button (below time set)
press time set for 3 seconds
press CE/E red button to return to calculation mode
thats it
Canon P170-DH Calculator Logo
2,684 people viewed this question
old marine
old marine
