Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
I can't format my PNY flash memory, and when it be connected to USB port the computer speed decreased. Heip me please.
  • 83 Answers
Hi friend first you install yours device then logoff yours system then logon again and click on start--->run --> write command cmd then click on ok,Now write commands step by step
1) cd\ press enter
2) c:/>format drive letter (eg d: f: e: etc) press enter
3) read message carefully and then press y
now yours flash drive formatted
Posted on Aug 05, 2010
Format a 16gb PNY Micro SD
Format it by using a device like a camera, the computer will not work to format this type of memory. I know this from own experience with 4 different computer in my house..
Jan 16, 2012 | PNY Attach? 16GB USB 2.0 Flash Drive
Where do i connect the pny?
You should have a USB port on your computer that this will fit into.
See this site for photos:
http://www.ehow.com/about_5365891_usb-port-look-like.html
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Aug 08, 2011 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
How can format usb
Hi there !
Just connect your usb flash disc into a usb port of your computer. Then right click mouse and you will see the FORMAT command there. Just run it and it will format your USB flash disc.
Feb 04, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I bought one pny pen drive of 2 GB after 4-5 mouths it gout courapted an when I try to explore/open and fromet a mesage is displyed by windows thati please insert disk drive in H:
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 14, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
MEMORY CARD REQUIRES FORMATING.HOW I DO THAT?
using a card reader, connect them to one of your USB port. once the pc had read your memory card, it will create temporary drive which can access via My Computer. once the drive appeared, right click on the drive and choose format.
best regards, lucgalman
Oct 09, 2009 | PNY 8GB Secure Digital High Capacity...
8gb PNY micro sd card isn't recognized in my samsung Alias
If the phone failed to format the SD card, try to format it through your computer. Connect the phone through the USB port located at the back of the tower. You'll be prompted that the PC detected 2 USB drives, the phone and the SD card. You will see it by going to My Computer folder. From there, right click the Letter drive represents the SD drive then select Format. I hope this helps.
Jun 16, 2009 | PNY 8GB Secure Digital High Capacity...
PNY 4G USB 2.00 Flash Drive
Solution:
i) try connecting it on the USB port present at backside or back panel of your computer tower, sometimes USB port present on the frontel panel of your computer might malfunctione or not working properly........
Nov 20, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Pny memory stick
once it is erased of your pen drive it is erased for ever
(you dont want to format it it will erase your date)
hope this helps :-)
Aug 31, 2008 | Electronics - Others
Pny usb 2.0 flash drive memory stick
windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
May 27, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Flash drive
What operating system are you running ??
If it,s windows 98 you,ll have problems, as they don,t like mass staorage devices, even with the drivers installed.
the other alternative, is to try on another PC And format it to FAT/FAT32 Or NTFS ( if your using XP )
Mike @ Compurepair.
Feb 24, 2008 | Electronics - Others
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
943 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Marvin
Marvin
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
