Question about Ridgid Saws
I need a manual for a Rigid Mitre table saw as I do not know how to turn on the laser light
  • 10,865 Answers
Hello. The laser guide will generate a red colored line on the work surface when the saw blade is spinning above 500 rpm. The
red laser line will appear as a broken line on the workpiece
when the blade assembly is in the uppermost position and
the motor switch is activated. This broken line will let you see
your mark and your laser guide line at the same time, and will
assist you in lining up your mark for more accurate cutting of
the workpiece.
Here is a link to all of the manuals, just find your saw and download the manual. Enjoy. http://www.ridgid.com/Tools/Support/?warrantyMenu=%23&warrantyMenu=%23&criteria=miter+saw&selectType=Owners+Manual
Posted on Aug 03, 2010
Where to put batteries for laser on a tooltec 1800w mitre saw part no.273102 ?
Michael!
I am not at all familair with your particular saw, but I have seen and used many other miter saws with lasers, so I hope this will help:
Many saws install the whole laser assembly right at the center of the saw blade itself. If you look, very likely you will see two pretty beefy washers, one on either side of the blade, right where the motor's arbor passes through the center hole of the blade. One of these washers is the laser itself. complete with batteries. Please unplug the power and take a close look; I'll bet you will be able to spot the lens of the laser.
If your laser turns on automatically when you spin the blade, this is almost certainly where the laser is. In the beefy washer is the light source, a couple of button batteries, and a centrifugal switch that closes when the balde sipns fast enough, thereby turning on the laser. When you release the trigger, the saw slows and stops, the switch is no long held closed by centrifugal force, and the light goes out. Pretty slick!
To replace the batteries, unplug the power and remove the blade according the instructions in your manual. Be aware that many saw blade arbors and their retaining nuts are LEFT HAND THREADED.
Look closely at the washer to see how it comes apart, and take the batteries with you when you shop for repalcements.
If you don't have the manual, speak up, and together we go over blade removal/blade changing, but it is pretty straightforward. Good luck.
Nov 14, 2017 | Saws
I have a Performance Power Tools PP1100MS mitre saw and i need to replace the blade but its not obvious how to do it and i have no manual.
Hi, I too have a performance power mitre saw pp1100ms and need to replace the brushes. I have the parts but no diagram...any advice please ????
Nov 10, 2013 | Saws
I have a Makita 10 inch compond mitre saw. My owners manual has been lost and I need the tables that show what degree to set the mitre and bevel for various degrees.
You can get it at Makita.com, type in yr modal number in the search bar, download a parts breakdown or a manual, if not u can order a new sticker from makita.
Jun 08, 2010 | Makita 10" Compound Miter Saw LS1040
Cannot find manual and need to do mitre cuts
for what brand and model number?? Let me know and I will try and help
Dec 28, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
Changing the blade on a power mitre saw
dont know about a manual, usually a button to push, maybe underneath, or a hole to put a dowel through?
Oct 23, 2009 | Saws
Looking for a site to download a manual
I understand that Denali is made by GMC. Here is the website for GMC miter saw manuals.
http://www.gmcompany.com/index.cfm?module=manuals&cid=54
See if the 10" miter saw with "redeye (R)" is the same as yours.
May 30, 2009 | Skil 3800 01 Factory Reconditioned 10"...
I purchased the Bosch saw blade on Ebay
If the arbors the same and you're running with in the RPM rating, it will be fine. But ALWAYS wear your safety glasses.
Mar 15, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Saws Logo
76 people viewed this question
Top Ridgid Saws Experts
John Trevino
Jim Thurston
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
