Question about Sharp AR-5316 Advanced Digital Imager Copier
The toner light is blinking always when switched on, but the toner is full. The machine does not operate.
    President:
  • 567 Answers
Hello there Troubleshooting a copier when it has problems is essential to saving time and money. Many problems are common and easy to fix, while others will require a visit from a repair technician. Learn how to fix the easier issues and when to call a repair person.
  • Remove jammed paper, probably the most common copier problem, by opening the front of the copier and following the instructions which are usually printed inside the unit.
  • Step 2Store paper in a cool, dry place. Jams can be caused by paper that is slightly curled or has been exposed to moisture. Sometimes starting over with a fresh **** of paper solves recurrent paper jamming problems.
  • Step 3Clean the copier of paper dust with a cloth and clean the glass to remove ink and other materials that have transferred from originals. Do this regularly and be sure to follow the manufacturer's instructions.
  • Posted on Aug 03, 2010
    • Hilton Bristol Aug 03, 2010
    • Learn how to replace the copier's toner cartridge. This will help you to troubleshoot copier problems such as lighter or darker areas on the page and is an easy thing to try as a possible solution before calling in a technician.
    • Step 5Call a repair person if you've checked for the simpler issues and are still experiencing problems. These might include unexplained noises, spots on the page--which are likely a problem with the developer unit--or if you suspect the problem lies in the drum unit. Drums can rarely be rebuilt, so a new one will need to be installed by a professional.
    Sharp Ar-5516 toner light problem continue blinking
    If the toner light has a line under it your waste toner container is full and needs to be emptied.
    May 04, 2016 | Sharp Office Equipment & Supplies
    Message the toner bottle is full please call the server machine printing rico 4500
    The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
    Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
    I hope this helps
    Jul 06, 2015 | Office Equipment & Supplies
    Low toner warning light always blinking
    maybe the toner t1810c is not original...try this code turn off the machine then press 0 and 2 at the same time then a value of 3 digit will appper just press start button...dont turn off the power other wise this toner warning will show again...repeat this procedure the next time u off then on the machine...hope this can help...
    Apr 05, 2013 | Office Equipment & Supplies
    Toshiba E-studio 166 error code c26
    hi. i have problem in my Toshiba e studio 166. that machine toner light is blinking always. i try so many time nd i fixed new toner also. but i cant get any result of this. pls help me to solve this problem....
    Mar 07, 2012 | Toshiba e-Studio163 Copier
    Even after replacing the toner cartridge the toner light remains on and the copier will not operate. I have tried agitating the cartridge with no effect. Occasionally on switching on it will operate for a...
    Hi Paul
    Please answer me a few questions and Ill look into your issue when I get some time later today
    Are you using Sharp original toner or after market?
    Is the light the "billard ball" one and is it on solid or blinking
    Is the drum light on also?
    What is the page count on this machine
    "clear, density select, clear, density select, dilpay blinks 00 then use arrows for up, zoom for down, to put in 22, press copy then arrow in 05, press copy.. result will be 3x 2 digits repeaed, clear to exit to start of service mode
    what is the drum count?, same as above but 12 instead of 05 for second lot of entry
    TRy doing clear density, clear density, then 10 copy, can you hear toner motor turning for 30secs?
    Dont play in service mode you can damage machine if wrong stuff is put in;)
    (clear then clear again to exit all the way out of service mode)
    Please post back results/answers
    Cheers
    Soulvisitor
    Oct 10, 2011 | Sharp AL-1217 Copier
    Lexmark E260dn toner light is still on after changing the toner cartridge
    Toner light is ON, I would assume that the light is solid and not blinking. You can press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the replacement toner cartridge if it is the one suitable for your region.
    If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
    For further assistance, please call Lexmark Technical Support.
    Apr 12, 2011 | Lexmark E260dn Laser Printer
    Error code 19
    E019
    Indicates that the waste toner case is full.
    Thereafter, if the waste toner case is not replaced after making a total of about 2000 prints
    (A4/LTR), the machine will indicate 'E019' on the control panel; the error code can be reset
    by replacing the waste toner case and then turning off and then on the power switch.
    If the waste toner case is not set, the light-blocking plate will block the light between the
    photosensors, causing the Waste Toner Case Full message to appear.
    Feb 04, 2011 | Canon imageRUNNER 2200
    Paper light keeps blinking, paper full, won't print
    Paper light blinking could mean a few things on this machine.
    There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
    Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
    Apr 12, 2010 | Brother HL-2040 Laser Printer
    My NP6012 stops and paperjam light comes on. Paper not being fed.
    Pick up wheels can be full of dust due the time storage.Keep on trying to make copies,the paper will clean the rollers every time it try to feed.
    Jan 28, 2009 | Office Equipment & Supplies
    Toner showing empty
    first, if you refilled your toner, the printer will always tell you, that you are not using original toner and red light will blink. second, if printer tell you every time to replace different color, then you need to clean a chip reader and chips on toners. take out all toners and pc drum. under toner rack there is a chip reader, clean it with pressure air and reinstall
    Jun 03, 2008 | Konica Minolta magicolor 2400 Laser...
    Sharp AR-5316 Advanced Digital Imager Copier Logo
    59 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
