Question about Nokia 6600
The battery ends quickly on my phone - Nokia 6600
    Scholar:
  • 104 Answers
How old is your 6600. Just remove the battery from the phone, keep it on a flat surface and rotate it. on a flat surface battery should not get rotated. But if it rotates, tht means you need to go for a change of battery. If you continue using the same battery for some months, that may cause damage to your mobile. So just do the test wat i told. It will indicate you for the change of battery or not..
Posted on Aug 03, 2010
Bt8500 phone, do you know of a fix for this phone to stop the calls ending after 20 minutes. New batteries fitted. If Googled it appears to be common problem.
No problem with mine. I charge them once the level gets low and never run out of battery.
I am using NiMH batteries as they can be recharged at any point. NiCad batteries lose power very quickly if charging when still holding a charge.
Dec 08, 2017 | Cell Phones
The cell looses battery too quickly?
The battery may be reaching its "end of life" and is unable to take a full charge. This can happen due to frequent charging, charging before fully discharged, age, or incorrect charger etc.
You should consider purchasing a new replacement and making sure you're using the proper charger with the phone OFF.
Mar 13, 2015 | Samsung GALAXY ACE II X Ace2x S7560...
Battery dies out very quickly. Sometimes, the phone will just shut down automatically.
Batteries (of ALL kinds) have limited lifetime, and it seems like your has reached to it's end!
I recommend you change the battery with a new one.
Proper care of the batteries may help extending it's lifetime. Keep the cellphone in a cooled temp. (if possible) and try no to overcharge the battery too often (means, disconnect when battery's full!).
May 10, 2010 | LG KU990 Viewty
Nokia slide phone which drains battery power very quickly. Have tried new battery to no avail. (Bluetooth is off)
The problem could be virus, scan your phone for virus and if you have done that and yet the battery still drain quickly, then, it means the battery terminal on your phone is corrode that is why it drains your battery quickly.
Change the terminals of your phone battery and you will see that your battery will last you longer.
Take care.
May 02, 2010 | Nokia 6500 Slide Cellular Phone
Phone just froze cant press any of the keys or anything. tried to turn off and turn back on but still nothing
I have the same phone. It does this to me all the time. I suspect that it is just a general problem. I end up taking the battery out for a few minutes and then restarting the phone. Usually after that it's fine again. This doesn't cure the problem forever, meaning that it will happen again, but next time just quickly remove the battery and restart. Hope this helps.
Dec 12, 2009 | Motorola Mobility W385 Cellular Phone
My nokia E61i battery is draining very quick and charging quick as well.
Your battery is close to it's last leg. What you should do is fully charge it, let it run until it won't turn on, and repeat this process 3 or 4 times. If this doesn't improve your phone life your battery is going dead.
My suggestion as a wireless expert is when you get a new battery you initially run it until it wont turn on, fully charge it and repeat this for 3 or 4 times. This will develop the high and low end memory of your phone battery. If you plug the phone in too early it will set the lower memory boundry to that level when you could still have up to 15% life left. The phone company will most likely tell you "These new phones don't require you to do that". Trust me, it can't in any way hurt the phone, and you're getting the best life out of a new battery.
Dec 02, 2009 | Nokia E61i Cellular Phone
Nokia n73 new battery charges quickly and
try without memory card and if problem persists pls go to customer care...
Aug 10, 2009 | Nokia N73 Cellular Phone
My p168
are u shutting off completely or just the calls are ending. if the calls are just ending quick....go to call center on the cell ...then genl settings...then more ...look for auto quick end (turn off)...this will do the trick for call ending...if the phone is totally shut off when calling or incoming call i am very sorry i have no suggestions
Nov 06, 2008 | Dual Electronics CECT P168 Cellular Phone
Battery problem
Hi mahek, time for a new battery I'm afraid. They don't last forever, and the symptoms you describe point to a failing batt. Thanks for using FixYa
regards
Graeme
Mar 12, 2008 | Nokia 6300 Cellular Phone
Nokia 6600 Logo
51 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
