Question about LG enV VX9900 Cellular Phone
I have a dead battery in my lg envy and my charger wont charge my phone but that same charger will charger my sisters phone. How can i get my phone to charge?
  • 1,557 Answers
Try your sisters battery on your mobile. if it powers up and your charger isnt working on your mobile then you have an internal loop fault in the power section of the mobile that directs power to charge the battery. its a big fault and is far cheaper to replace the phone than to have it repaired.
sorry
take care.
Posted on Aug 03, 2010
My LG-VX9200 wont turn on and the battery wont charge. I assume is the battery, its a practically new phone. It hasnt get wet either. What can it be? Thanks in advance
Before you conclude that the battery is the problem, i suggest, you get a similar charger to charge your phone first, if the similar charger charges the phone, then, ii means you are having charger problem, but if it does not charge the phone, you should be considering the idea of getting another battery to see if it will charge on your phone.
The problem can also be that, the charging port of your phone is bad, you can use your charger to charge a similar phone and see if it charges, if it does, then, the problem is either th battery or the charging port.
Check the following one after the other to detect what the problem is,
1. Try use a similar charger to charge your phone to see if it will charge.
2 Get a battery from someone that as a similar phone to test your phone to see if it will power up.
If it works with your phone, get a new battery for your phone, the one you have on it is dead and will need to be replace.
Take care.
Jul 18, 2010 | LG enV3 VX9200 Cell Phone
Just bought new Envy 3 and it wont charge. Tried
Will it charge in the car from a car charger and did they test it at the store before they gave you a new one. I heard that they have had problems with the new ones having a defect with the chargers. That they had the wrong homechargers in the boxes.
Jul 22, 2009 | LG enV VX9900 Cellular Phone
Charge port is broken how do i charge the battery
you need a Universal Battery Charger, the one i have is a Omnipotence AC Travel Charger Adaptor, its for all type of Mobile Phone Battery Batteries. i got mine off amazon only £5
Jun 29, 2009 | LG enV VX9900 Cellular Phone
Lg Vu wont charge
First you must determine is it the charger faulty or the phone ? , have you a friend with the same phone if so try her or his battery to see if your phone is ok if so try the charger with your battery and see if it charges if it does get a new charger , if it did not charge or work with your friends battery or charger the sorry it would be cheaper to buy a new phone than try to get it fixed ...
if you haven't got a friend with the same phone have a local electrician check if there is an output from your charger . if there is it may just be the battery try a new one if still no luck it is probably the phone's charger circuit gone pop ,, sorry .. vortash
May 13, 2009 | LG Vu CU920 Cellular Phone
Wont charge, dead battery
make sure that your charger is not bent, i had the samd roblem sometimes you just have to get a new charger or just get that one to position right so that it will charge the phone
Apr 05, 2009 | LG VOYAGER VX10000 Cellular Phone
LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Jan 31, 2009 | LG Shine CU720 Cellular Phone
yeh same problem with me, take the battery out, put it back in, then stick the charger in and it will work
Oct 10, 2008 | LG Shine KE970 Cellular Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
Charging My Phone
it is not broken try changing the battery or charger...if that does not help take the phone to a mobile service center or mobile technician and have them service the mainboard..
Feb 14, 2008 | Motorola Mobility RAZR V3
LG enV VX9900 Cellular Phone Logo
138 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
