Question about Numatic GVE370 Canister Wet/Dry Vacuum
Water will not go through hose from bowl to clean carpet. Only bought it today and thought it would work first time.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Did you unclip the pickup tube and place in the water container, look under the motor assy its a thin tube with a filter on the end. check all hose are clicked in place
Posted on Aug 03, 2010
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
Why does my machine vacuum has very little suction while the there is no solution come out of the hand hose?
Make sure you have the hoses hooked up properly. Also check that there is no obstruction/blockage in the hose. Otherwise, contact your friend.
Apr 26, 2016 | Vacuums
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
I have a Hoover SpinVac SpinScrub machine and have used it seven times. The last time I used the machine to clean my carpets, it would not **** up the dirty water. I clean it out each time I use it, but...
The most common reason for lack of pick-up is that the lid is not fully seated on the dirty water tank. Be sure to hook it in front before latching it in the rear. Another common issue is that the duct is missing from the front of the lower tank. The duct is removed to install the attachment hose, and must be put back in place before trying to clean carpeting. It is a square plastic piece - about the size of a slice of bread - which slides in and out of the dirty water tank.
Feb 21, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Our Bissell 9200 carpet cleaner will not spray cleaning fluid through the tools nozzle. With the tool dial set to "floor" fluid comes out of the front nozzle. With the tool dial set to...
Assuming this is the pro heat version
Most likely you have some debris blocking the system. You need to follow the hand tool cleaning instructions.
remove the hand tool and manually wash it
select the tools cleaning option
place the tube in a bowl of clean water and allow it to **** the water up - this should clean out any blockages in the pipe.
Dec 14, 2010 | Bissell 9200 Upright Vacuum
Carpet cleaning attachement won't work
its likely the motor has sezed up or there is a fult in it it should run but if its stuck up it cant run,
Jun 26, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Clean water coming out of sides
Hoover SteamVac Ultra (model F5883-900) Threw it away, and had to buy a new machine. Sorry, but I found it more difficult to deal with the housing unit on the machine and just couldn't deal with it anymore. I hope you have better luck than I did with it. I couldn't find ANY help on ANY web sites for this model, just too old I guess.
Jul 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Bissell carpet cleaner
If water is spraying from the tool hose, then check the heater for a blockage. If the heater port is blocked, then the water can't flow back down to the spray nozzles, which could also be clogged. Most likely a clogged heater, it is in the handle.
May 11, 2008 | Bissell 1699 ProHeat Clear View Upright...
Eureka Atlantis 2591A Extractor - Won't spray
Hard to say without seeing it, is there a function type knob that you would switch from carpet to hose? Did the hose attachment lid close ok? Other then take, if this is new, it has a years warranty on it, just take it to a waranty shop for repair.
Apr 20, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Numatic GVE370 Canister Wet/Dry Vacuum Logo
278 people viewed this question
Top Numatic Vacuums Experts
Chris Nomland
Chris Nomland
Andrew Taylor
Andrew Taylor
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
