Question about SanDisk Sansa e260 MP3 Player
Looks on but nothing happens
Hi I connected my MP3 To my pc to charge and slowly the light started going off,and now it looks like it's stuck, as if it's lite but nothing happens. I can see it's on only if I look at it from the side. Any suggestions as what to do or what happened here? Never happened before
  • Nor16 Apr 26, 2008
    Hi thanks for your suggestion. I tried holding and playing with buttons but nothing. Eventually the battery died and it turned off.
    Then I tried to start charging and got heated and it eventually turned itself off. Was ready to go back to the shopI bought it from and see what's the matter. Then I decided to plug it in agian this morning and so far it's charging and is also working properly. Have no idea what was all this about.
    Hope this doesn't happen again.
    Thanks again for trying
  • Nor16 Apr 27, 2008
    I'm glad that my problem and posting helped someone.
    In my case nothing helped, even holding the button for the 20 secs.
    Anyway, hopefully won't have more problems.
Jokera, that second suggestion solved my problem tks
Posted on Apr 26, 2008
  • 46 Answers
Did you try turning it on and off. if that doesn't work try holding the power and play buttons at the sametime for 20seconds.
  • bob terry Apr 27, 2008
    your welcome
I've put mp3 files on, but nothing's playing
Simply the player is dead! If you connected player to the pc with no problem it means NO ERROR messages and the driver for the player is ok, you have copied all the mp3 files in ONE directory to the player and nothing happened there are only two possibilities either the PLAY button is stucked or the mp3 player is dead!
Jan 08, 2014 | Audio Players & Recorders
Frozen MP3 player - MPIO HD300
Have you tried downloading the specific drivers for that MP3?
Here is the site...choose your player then download and install...reboot and see if it solves your problem.
Feb 29, 2008 | Mpio HD-300 MP3 Player
I charged a small sony pocket e reader, and tried to turn it on, it was slow, not really knowing what was going on I kept trying. teh light going from green to red, to amber to now nothing and I can't...
Hi nellvandenel,
Looks like the reader is missing charge. You can try these steps:
1. Connect the reader to the computer
2. While Reader is connected, hit the "Reset" button at the bottom of the reader
3. Check if a red steady light comes on, if not, try the reset again
4. Leave the reader connected for 15-30 minutes to allow it to charge
5. Disconnect the reader and check if is operational now
Jun 04, 2011 | Sony E-reader Portable E-book MP3 Player
Sansa 280 MP3 player won't charge. When attempting to charge, it
This problem indicates that it is stuck from inside . You just keep on pressing menu option and keep on pressing the center button for 2 minutes it will solve your problem .
It actually worked for me that's why I am sharing this .
If you still have a problem let me know .
Hope this helps .
Do rate my solution .
Dec 04, 2009 | SanDisk Sansa e260 MP3 Player
Samsung mp3 player YP U3
take your mp3 off the usb and go into the settings, you should find settings for the usb connection , ,, one of the options should be highlighted , chose the other one and try again,,,, your mp3 was set to charge only just pick the other setting and it should work. that happened to me once
Aug 17, 2009 | Samsung YP-U3 MP3 Player
Nothing happens when I plug in my Nextar Mp3 player to the comp.
I PLUGGED IN MY MP3 PLAYER TO THE COMPUTER AND THE SCREEN ON MY MP3 PLAYER LIGHTS UP BUT the normal screen image for when you normally plug it into the computer ISN'T THERE AND I CAN'T ADD MUSIC ON MY MP3 PLAYER.
Jun 16, 2009 | Nextar MA7151B MP3 Player
Not charging :(
there may be a problem with ur charger. if u have the warranty card for ur set u can replace the charger with another 1....
plz do comment and rate.
Aug 21, 2008 | Samsung YH-925 MP3 Player
Problems with my MP3 A3000 20 Gb sony
I had the exact same problem. It was just after I pretty much filled all the memory up with music too. Nothing would happen even when I connected it up to the power supply.
It's possibly because it has crashed trying to shut down or start up as I could hear internal whirring when I put it to my ear and moved it around. Try using a paperclip or thin nail in the small reset hole at the bottom of the player and that should reset whatever it is stuck doing. Mine started up again after this and all the songs were still intact.
Aug 17, 2008 | Sony Network Walkman NW-A3000 MP3 Player
How to charge my creative zen mp3 player
Just connect your Zen onto your PC (NOT LAP TOP) on a USB.
If does not start charging (you´ll see arrow and pause/ play buttons flashing slowly) then you need to RESET your ZEN.
How to reset: You´ll find a tiny little hole by on/off button on the side. With ZEN connected to the PC USB or onto wall charger try turning ZEN on, it doesen´t matter if it turns on or not. Then insert a sowing pin or office paper clip end in this reset hole for a few seconds and release. Give it a couple of seconds and see the lights go off onto charging mode. LEAVE IT CHARGING for 24 hours. Make sure your PC will NOT turn itself on safe mode or hibernates in this period, it has to be ON for charging, at all times.
This is it.
Louise Passalacqua.
Jul 08, 2008 | Creative Labs ZEN V Plus MP3 Player
My YP U3 don't turn on
DONT TROW IT AWAY!!!!!!!!! push hold buton and the play/rec butons, this will reset your system, and than! tcharã! ok again!
Apr 03, 2008 | Samsung YP-U3 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
