Question about Teac Audio Players & Recorders
Need to replace the belts (2) on a cx-650r cassette deck. any info on belt locations and procedure (disassembly?)?
  • 9 Answers
SOURCE: Source For Replacement Belts
http://www.studiosoundelectronics.com/cassette.htm
http://www.turntableneedles.com/index.asp
Posted on Oct 27, 2007
  • 54 Answers
SOURCE: Replacement belt for Tascam 122
well, after a quick search on the net, the only place I can find that still carries them is consolidated electronics in the USA. I have ordered from them years ago and they were very good. You will find an online catalog and how to measure your belt to get the right one.
NOW.....when belts go, the rubber deteriorates with age. The belts stretch. Carefully, without stretching the belt further, place it on an inch ruler, belt laying flat. Make tight corners on the belt by pressing one side against the other and measuring the length against the ruler. The belt length is the measured length times 2. Write this number down !. Try stretching the belt A LITTLE....if it snaps back to length, then it isnt in too bad a shape, and you can order a belt 3% smaller and one 6% smaller. If you stretch the belt and is slooooooowly comes back, then the rubber has turned to licorice. If it If your belt has already stretched and it is still in one piece, when you measure it, it will be too big. I would order several belts, one 10% smaller, one 13% smaller and aonther 16% smaller, that way you should get the right one. If the belt has broken, without stretching it, **** the broken ends together and tape them butted together, then measure the belt. Its been a long time since I've done a 122', but if there are other belts in there too, order them as well. When one belt goes, there are more to follow in the very near future. I would first try contacting Teac/ Tascam to see if the correct belt is available from the factory, or possibly an entire belt kit !. If you need more instructions on belt measuring, go to : http://www.ceitron.com/passive/flatLbelt.html and follow instructions at the top of the page.
Good luck.....Rob
Posted on May 09, 2008
Kidyubyub
  • 143 Answers
SOURCE: 1994 Corvette Cassette/Radio?Replace cassette "drive belt"??
Donne Trav, you can take that belt to an electronics shop (your neighborhood shop is best). They will most likely have replacement belts. They will also have a tool that measures the belt so you know which size to get. I used to fix T.V.'s and VCR's. Its the best method when you cannot source an original belt. As far as the diagram, I would need a model # of the radio to even start a search for such a thing.
Posted on May 16, 2008
SOURCE: teac a 303 cassette deck
Posted on Dec 05, 2008
  • 336 Answers
SOURCE: Fisher stero cassette deck CRW47H
Your best bet is to get generic replacement belts at www.mcmelectronics.com You will have to measure each belt's length and diameter, also width if its a flat belt.
Posted on Feb 01, 2009
Do you know where I can get replacement belts for Awia dual cassette player, Model CX - NDV 526U Digital Cassette Reciever
http://tapedrivebelts.com/. If they don't have you belt they will be able to guide you the right direction. Ebay is a great source for these as well. If you know the length then there are hundreds of online places to get them.
Apr 16, 2016 | Audio Players & Recorders
Thaks for helping. My tape deck door has suddenly stopped working. the tape is inside and when i turn on the wpower there is a clicking sound. it is a TEAC AD-500 CD player/reverse cassete deck
Without physically looking at the cassette deck myself, I cannot be 100% sure the tape is wrapped around the pinch roller and capstan. The capstan is the chrome rod which the rubber pinch roller pushes to regulate the speed of the tape moving across the head. However it is approximately a 90% chance the take up reel for the tape stopped working from a bad tape or a loose belt which drives the tape take up reel. The clicking sounds like it could be the auto reverse solenoid because it thinks the tape has reached the end of play. The fun part is to remove the tape which you may have to disassemble the front panel if you cannot gain access to the tape from the top or bottom. You will need to cut the tape and remove it from the capstan and pinch roller to open the cassette door. Sometimes you can remove the capstan to free the tape. Once you have cleaned all the tape out of the unit make sure the belt for the take-up is good. If it is glazed, cracked, loose or broken order a belt. Clean all the pulleys and capstan and replace the belt. Your unit should be functional after the above procedure.
Jul 14, 2011 | Teac R-H300 Dual Cassette Deck
Cassette will not exit, nor play and does a clicking soud
Cassette will not exit,eject nor play and does a clicking sound, one side of cassette door will not close.
Jun 15, 2010 | Sony TC WE835S Stereo Dual Cassette Deck...
NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Dec 25, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
I need replacement drive belts for an Onkyo
i bought some today from **** smith electronic store , i paid $7.97 for a pack of ten assorted sizes
May 18, 2009 | Audio Players & Recorders
Lock on panel keep turn on and no operate at all
**** smith electronics stock packs of 10 assorted belts , i bought a pack yesterday for $ 7.97 Au
May 11, 2009 | Sony CASSETTE DECK Single Dual Cassette...
Aiwa NSX-V70 Cassette Deck Belt Replacement
Mark
try www.partstore.com I think you can get what you need there!
Please rate my response!Thanks!
Jan 15, 2009 | Audio Players & Recorders
TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
47 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
