Question about Toshiba Office Equipment & Supplies
Toshiba eStudio 203SD. ADF doesn't work despite tech "fixing" it. Put docs in ADF, message "Check ADF/RADF."
    President:
  • 2,072 Answers
Most likely there is a sensor that is out of place. That is the most likely problem. If it is not out of position then it may have failed. But what is happening is when you insert the document into the feeder, the machine is detecting a paper already in the feeder.
Posted on Aug 03, 2010
  • TOMMY
    TOMMY May 21, 2014
    IT RESETS WHEN THE FEEDER IS OPEN/CLOSE SOMETIMES YOU CAN MAKE COPIES THEN IT COMES BACK
Toshiba e 233 is error code C550 how to clear
Communication error has occurred between the RADF and the scanner.
(1) Check if the harness connecting the RADF board and SLG board is disconnected or open circuited.
(2) Check if the conductor pattern on the RADF board is short circuited or open circuited.
(3) Check if the conductor pattern on the SLG board is short circuited or open circuited.
(4) Replace the RADF board.
(5) Replace the SLG board.
Jul 16, 2016 | Toshiba Office Equipment & Supplies
Estudio 203sd adf
What is the brand of the machine and describe the problem in more details.
Oct 16, 2013 | Toshiba e-Studio 202L Copier
How do you fix error code c55
Here are the steps they recommend in the users manual for a c55 error.
5.1.11 Optional communication related service call
[C55] ADF I/F error
[F11] ADF I/F error
(1) Check if the connector CN71 on the ADF/RADF board is disconnected.
(2) Check if the relay connector between the ADF/RADF board and the PFC board is disconnected.
(3) Check if the connector CN246 on the PFC board is disconnected.
(4) Check if the connector pins are disconnected and the harnesses are open circuited.
(5) Check if the conductor patterns on the ADF/RADF board and the MAIN board are short circuited
or open circuited.
(6) Replace the ADF/RADF board.
(7) Replace the MAIN board
Jan 05, 2013 | Toshiba e-STUDIO166 Printer
It shows in the screen place doc.feeder in the down posotion
90% it is the RADF PCB. Before replacing it check the sensors and switches of the RADF in 03 mode. Refer to page no 2-29 of SERVICE HAND BOOK.
Dec 05, 2012 | Toshiba e-Studio 232 Black and White...
We have a toshiba e studio 181 copier, it have an error messsage sp5. what will we do?
is that really e-181 and sp5?maybe that error is C55 which is adf i/f error.communication error between the adf and scanner
Mar 19, 2012 | Toshiba Office Equipment & Supplies
Brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
I have a message coming up that I don't know what it means.
ADF = Auto Document Feeder (Usually on top)
RADF = Rear Auto Document Feeder, (On the back)
Something is stuck in one of these, a piece of paper, foam, paperclip, twist tie . . . it could be anything. Follow the squealing sound and check the paper feeder rollers.
Find what is in the way and remove it.
Cheers.
Jun 22, 2009 | Toshiba e-Studio 161 Copier Copier
The copier keeps saying to put doc. feeder down and i it is. I ha
When you lift/ open the ADF you should see a tab in the back corner (slightly in from the corner) of the ADF. This tab is for the machine to see that the ADF is closed. Make sure tab is there. On its sister model they used a depression switch, check that and make sure it is there and working properly.
Jan 05, 2009 | Toshiba 2060 Copier
472 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
