Question about Acer Aspire One PC Notebook
When I turn on my Acer laptop.. It says that "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair this file by starting windows setup using the original setup CD-ROM. Select 'r' at the first screen to start repair". That's what it says. But every time I press "r" it does not go on. It goes back to this.
  • neniker_cb Aug 03, 2010
    I cnt reinstall it because I can't go on. As soon as I turn it on. That's what it say. I don't know how to fix this.
  • 1,557 Answers
Re install windows.
Posted on Aug 03, 2010
  • Jim Winger Aug 03, 2010
    If there is a corrupt disk caused by a disk failure, this won't do much good. They need to determine what went wrong.
  • sonic boom electronics
    sonic boom electronics Aug 03, 2010
    a sys32config corruption is almost always due to a trojan attack there fore the cheapest and quickest way to fix it is to re install ops system and use a good anti viral program.
    Guru:
  • 1,082 Answers
This might do it:
http://support.microsoft.com/kb/307545
nassimjd
  • 104 Answers
SOURCE: \Windows\System32\Config\System; Repair w/CD-ROM; NO CD-ROM
if you can get an external cd/dvd drive from a friend, then you could solve the problem.
other solutions would mean that you will reinstall windows again. This takes more time and has a few tricks to be done from a flash drive.
Posted on Mar 24, 2009
tcobiz
  • 35 Answers
SOURCE: need original setup cd-rom windows xp media
You can get the downloads and purchase the cd's from Microsoft, got to
www.mcrosoft.com and start in support and then downloads and you should be able to navigate your way around that area and you will find it..
Posted on Oct 23, 2009
  • 10406 Answers
SOURCE: netbook acer aspire one Windows could
Put the original setup CD-ROM into your CD-drive.
Restart the computer.
Tell it to "boot" from the disk in the CD-drive.
Choose "repair an existing Windows installation",
and let it fix the problem.
Remove the CD-ROM disk.
Restart your (repaired) computer.
Posted on Oct 09, 2010
  • 149 Answers
SOURCE: When I turn it on, I get a black screen which
Get your windows restore cd (it's probably in your box) and boot to it. You may need to enter the boot selection menu and select "Boot from CD-ROM drive". It should then prompt you to press any key to boot from the cd, which you should do. Just follow the prompts, wait for the disc to load, and then press "r" for recovery when you are prompted.
The system folder does not delete itself, so run a virus scan as soon as you restore your computer.
Posted on Dec 31, 2010
  • 68 Answers
SOURCE: Error on startup: Windows could not start because
Theres a corrupt file already in your system and needs to reformat and setup, this is the best solution for this one because this can be a cause of virus, even with the recovery cd the virus will still function so the best thing to do is to format and setup it again:
heres how to do the setup:
1. insert the windows XP, VIsta or 7 CD
2. upon turning on the laptop, wait for the press any key to boot from CD, then press any key.
3. the setup will now open, follow the steps of the setup afterfards.
if your laptop first boot is not the CD then enter the bios setup by pressing F2 or Del when powering ON the laptop then goto to Boot Device priority menu. set the first boot to be the CD or DVD Rom.
Good Luck!
Posted on Mar 31, 2011
It won't load windows! windows won't start because the following file is missing or corrupt. windows\system32\config\system.
try starting in safe mode by pressing f8 key on system boot ,
looks like you may have hdd problem, if you get message 0disks filling the screen hdd needs replacing
Feb 22, 2011 | Aspire Acer AS5315-2856 Laptop
My acer wont start up,when turned on i get a message---windows could not start because the following file is missing or corrupt:\windows\system32\config\system.have tried f2 andf8 options,nothing works,can...
Your windows is corrupt. Your only 2 choices are to get a windows disk of the same version you have (windows 7, vista, xp) and run the recovery console and manually install this file from the disk. On windows 7, and maybe vista, you can get a "repair my computer" option. Your second option is still get a windows disk of your version and make a clean install on your hard drive. You can get a disk online, since you have a valid serial code or you could contact Acer or where you bought the laptop, and see if they can send/give you one.
Feb 09, 2011 | Acer Aspire One PC Notebook
When i turn on i get this "Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM " "you can attempt to repair this file by starting windows setup...
Looks like the whole folder is missing ???
Reinstall Windows XP in a different folder then reboot.Find your data files and back them up on a different medium. USB stick, etc....
Any 3rd party programs may not beable to be save as they need to be reinstalled.
After retrieving the files reformat the HD and reinstall windows on a fresh start.
Aug 24, 2010 | Acer Aspire One Netbook 8.9" Notebook
At start up the ACER logo appears as is normal and then instead of going through the remainder of the boot process, the following appears on the screen (with a solid black background): Windows could not...
For the Hal.dll file missing problem do this:
1.Insert and boot from your WindowsXP CD.
2.At the first R=Repair option, press the R key
3.Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4.Type bootcfg /list to show the current entries in the BOOT.INI file
5.Type bootcfg /rebuild to repair it
6.Type exit and take out the CD ROM
Sep 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
CANNOT BOOT WINDOWS XP ON MY ACER ASPIRE ONE LAPTOP
hi..if u have a Windows XP installer just put in the CD/DVD player then auto run the win XP and make install the new windows/OS and make a choice leave the current files if you to re cover the files using a new install OS/Windows..Good Luck and Have a Nice Day...
Jun 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Apr 08, 2009 | Acer Aspire 5610-2328 Notebook
Acer aspire one ZG5
sure you can ..
you should look for Acer Erecovery managment in all programs.
that will help you is restoring your system.
Thanks
Kevin
Nov 16, 2008 | Acer Aspire 5100 Notebook
Acer Aspire One  PC Notebook Logo
226 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
