Question about HP Compaq dx2300 Microtower - RT950UTABA PC Desktop
Audio driver is available,enable but no sound coming on speaker & headphone what's problem pls help me
  • HP Master
  • 4,924 Answers
Reinstall the driver and instal the UAA driver first It is present on downloads on the site ..under windows xp ..
Posted on Dec 22, 2011
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
Intel(R) Desktop Board D945GCL,Window 7 ultimate is installed.After installing Audio Driver (Version 5.10.5208.0) Sigma High Defination Codec,in speaker properties,Jack is showing Jack information not...
Please ensure that your bios setting is enabled for audio.
1. Have you installed the correct windows 7 driver or have you configured with the vista driver?
2. If you have installed with windows 7 driver, check it for 32 bit or 64 bit and you are installed perfectly!
3. Check the windows service. Go to "run", type "services.msc" and press enter. In that opened window, direct to "windows audio". Open it and check the service is started or not. Also ensure that the startup type is set to be "automatic".
Hoping you will be short out!
Aug 19, 2011 | Intel D945GCL Motherboard
I cannot hear any sound from my headphone n it shows no audio device.... Plz help me guys>>>
101 % Working first you have to download
1. Universal audio architecture which will enable your motherboard to detedt audio driver it can be downloaded from here
http://hotfile.com/dl/93757632/f560457/motherboard.driver.audio.realtek.azalia.x-fi.exe.html
2. then u should install audio driver which comes in motherboard cd...
Or please provide me with the model number
Jan 26, 2011 | Audio Players & Recorders
No HD audio via HDMI after upgrading to Windows 7.
Hi, pls go to control panel/sound & audio devices. Then select your output audio device there. It's probably set on your headphone I think. If you are getting audio from headphone , this means that the audio driver is installed.
Pls contact me for further info.
Feb 10, 2010 | EliteGroup Lga 775 GF7100PVT-M3/MCP73T-M3...
Sound not working
Please check that your audio cable from speaker to CPU is connected properly or not ,if not pls connect .If still sound not coming then pls check the sound card is enable or not in your system BIOS.If not pls enable it and login through administrator and check ,If still sound not coming then pls check the sound driver is installed or not if not pls install it and check .if still issue not resolved pls check your speaker is working or not by connect with another system.If still not resolved then problem with your sound card in the Mothaeboard get it repaired by Vendor.
Nov 16, 2009 | Acer Aspire™ T180 PC Desktop
My computer says i have no audio device it saying that another hardware might be using it.
There are a problem with sound driver.For this pls check that your sound card is enable from system BIOS.iF NOT PLS ENABLE IT FROM BIOS .After that install your compatible sound driver from your Motherboard CD or download from vendors site.after that if still sound not coming pls check your audio cable from speaker to cpu .
Nov 16, 2009 | Microsoft Windows Vista Ultimate Edition
Gigabyte 865 motherboard GA 8I 865 GVM SOUND DRIVER PROBLEM
none of the mixer lines are muted are they ?
If you double click on the speaker icon in the system tray or go to audio / sound in control panel and check in there.
Also have you got the speakers / headphones connected to the correct port ?
Apr 14, 2009 | Intel 865G Motherboard
No sound
Hi
Pls check in BIOS in advanced options, if the onboard audio is enabled or not. If not, enable it.
Pls check if the windows audio is enabled in services.msc.
If it is listed, make sure tht it is enabled.
If it is already enabled, stop the service and restart it.
If it still doesnt work, then download the driver from the yamaha website and then install it.
Feb 04, 2008 | Creative Labs E-MU 0404 Sound Card
No audio
Hi
Pls check if the audio settings on the monitor are correct. Along with the monitor menu button, there will be another button for audio for some models. For other models the audio option will be available in the menu button itself.
Pls check with another set of powered speakers and not headphones.
Also check for the drivers and any driver updates for your sound card.
Hope this helps fix your problem.
Jan 28, 2008 | Acer AL1717 17" LCD Monitor
HP Compaq dx2300 Microtower - RT950UTABA PC Desktop Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
